588,137 active members*
6,683 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Touch plate, Probotix PBX-RF board, and Mach3 software?
Results 1 to 7 of 7
    Feb 2008
    263
    I tried to wire the touch plate to the PBX-RF board but when I plugged a stereo phone plug into a mono phone jack, the "Digitize" light in the "Diagnostics" window stays on. Do I need a mono phone plug or can I cut the tip off the stereo phone plug? In the "Input Signals" dialog box, I set the "Probe" to enabled, port 1, pin 13, and active low. I set the X, Y, and Z Home Switches to enabled, port 1, pins 10,11, and 12, and active high.
    Mar 2007
    2083
    Hi Jeff
    to use a stereo jack plug as a mono jack plug
    just connect the ground connection to both the "ring" and "sleeve" terminals
    and the signal wire to the "tip"
    John
    Attached Thumbnails Attached Thumbnails stereo jack plug used as a mono jack plug.jpg
    Feb 2008
    263
    I got the touch plate working after using different phono plugs and jacks. I have USB numeric pad usually used for notebook computers. How do I assign a key stroke command to VB code to start the code running? I'm using the VB code from Login
    Mar 2003
    35538
    Quote Originally Posted by jeffmorris View Post
    Using a screen designer, add a button to the screen with a hotkey assigned and add the VB code to the button.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2007
    2083
    Hi Jeff
    its good to see its working
    in the past I've had problems when using either budget connectors or
    in one case one combination of different makes of plug and socket didn't
    work
    I've no experience with VB code , hopefully someone will have an answer for you
    John
    PS while I've been typing I see Gerry has posted the answer
    Feb 2008
    263
    Is there a list of unused numeric pad keys? I tried a few screen designers and they confused me because of lack of good documentation.
    Mar 2003
    35538
    There are videos on using the screen designers on the Mach site.
    There are also lists of shortcut keys there as well, but I've never seen a list of unused keys.
    Gerry
  1. Touch-off plate for CNC router?
    By CanSir in forum LinuxCNC (formerly EMC2)
    Last Post: 03-28-2019, 11:53 PM
  2. Touch off plate problem
    By raf61 in forum LinuxCNC (formerly EMC2)
    Last Post: 01-01-2012, 10:16 PM
  3. Touch off plate
    By rich_cree in forum Benchtop Machines
    Last Post: 06-03-2010, 06:05 PM
  4. electronic touch-off plate
    By project5k in forum Benchtop Machines
    Last Post: 02-25-2009, 08:20 PM
  5. Touch Off Plate
    By gunlocators in forum Benchtop Machines
    Last Post: 10-07-2008, 07:25 PM
