587,974 active members*
4,432 visitors online*
IndustryArena Forum > MetalWorking Machines > Toyoda > Toyoda FV850S "Arm motor dry run" error message
    May 2007
    122
    Our three year old Toyoda FV8505 is showing an error message of "Arm Motor Dry Run", error# 1072.
    Toyoda no longer has any local support in Florida so we will need to try and fix this ourselves.
    May 2007
    122
    Re: Toyoda FV850S "Arm motor dry run" error message
    We think we found the issue. There is a small oil bottle for this inside the machine that was empty. We ordered the oil for it and will see if this clears the alarm.
  1. "master encoder state error" AB ultra100 error message
    By ShapeShaver in forum Servo Motors / Drives
    Last Post: 07-31-2013, 04:09 PM
  2. Bridgeport Ez Trak SX - "No Cable" Error Message
    By sullivnc in forum Bridgeport / Hardinge Mills
    Last Post: 04-10-2013, 12:03 AM
  3. Replies: 2
    Last Post: 02-17-2013, 02:49 PM
  4. Desperate for help. Roland CJ-60 "Capping Error Message"
    By jmmccann in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 12-03-2011, 07:01 PM
  5. V2XT error message "DRIVE FAULT detected (0,z,y,x) check log"
    By rfdoyle in forum Bridgeport / Hardinge Mills
    Last Post: 10-08-2007, 09:35 PM
