603,855 active members*
3,371 visitors online*
IndustryArena Forum > MetalWorking Machines > Toyoda > Toyoda Tool change help
Results 1 to 6 of 6
Hybrid View
frank12933 Toyoda Tool change help 01-27-2011, 11:54 PM
Toyoda_Anthony Hi Frank, I'm contacting... 01-31-2011, 06:05 PM
Toyoda_Anthony OK Frank, I just spoke... 01-31-2011, 07:00 PM
frank12933 Thanks Antony, I call them... 02-01-2011, 12:02 AM
jam-man don't know if you got it... 02-19-2011, 07:43 PM
1234567 tool change 03-02-2011, 06:04 PM
    Nov 2007
    8
    Hi Anthony
    We bought a 1988 Toyoda FH55 with Fanuc 15M control.
    When I call a tool change it show a message "Can not tool selection"
    any idea what I should check?? This machine had coolant thru spindle option but I don't know which M code to turn it on, can you help.
    Thanks in advance.
    Jan 2011
    Hi Frank,
    I'm contacting our service people with your question, I'll get back to about solutions in a bit.
    ,Anthony
    Jan 2011
    OK Frank,
    I just spoke with our service techs and they said you should call 800-257-2985, which is our direct service line at our headquarters outside of Chicago. They are going to need some additional information, including the serial number of your machine. If you have any additional questions, I'll be happy to help.
    Nov 2007
    8
    Thanks Antony, I call them latter on.
    Jun 2009
    12
    don't know if you got it fixed or not, but this is an eazy fix. the machine thinks that it has a tool staged to put in the spindle. just give it a plane M6 command and it should preform the tool change. if it places a tool in the spindle, remove it. if not look to see what tool it thinks that it has in the spindle and remove that tool from the magazine. everything should be good to go from there.
    Mar 2009
    291
    tool change
    yep..thats what i do with out fh55
  1. Toyoda FV65/ Fanuc 15ma tool change macro
    By NJohnson in forum Fanuc
    Last Post: 02-27-2020, 07:50 AM
  2. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  3. Replies: 4
    Last Post: 02-01-2011, 03:10 PM
  4. Replies: 0
    Last Post: 02-14-2010, 07:26 PM
  5. orient tool for tool change Hall effect?
    By Luslugger in forum CNC Machining Centers
    Last Post: 04-25-2009, 12:24 AM
