587,180 active members*
4,996 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Training material needed for beginner..
Results 1 to 7 of 7
    Jan 2013
    Greetings! I am new to Milling (little higher mechanical aptitude with 9 months intensive hands on work, 3 years of 2D drafting, guided by 30 years exp. ) and brand new to CNC Zone. I know the basics and need to gain confidence. I want to be able to rely less on my teacher and show more initiative. Does anyone have a training curriculum that works easier to harder? Any help/advice/facts/ect. is great appreciated!
    May 2004
    4519
    Start with a scale and scribe and file. Work your way up from there. Look into the NTMA, ToolingU and other training materials.
    Jan 2013
    Definatly looking into both. Do you know where I can obtain simple plans or projects to mill. I have mills at my disposal and want to teach myself.
    May 2004
    4519
    The NTMA blueprint reading course has some blueprints. The certification program has project blueprints. Many starting machinists make their own vise stops, tooling vises, and tool setting dial indicator blocks as first projects.
    Jan 2007
    243
    try your local JR colleges, sometimes they have courses in machining.
    www.WebMachinist.Net
    The Ultimate Online Source for Machinist Related Stuff!
    Sep 2008
    117
    A sinebar will be useful if you stay in the trade. You can make it now and heat treat/grind later.
    Gene
    Jan 2009
    123
    Just the basics on measuring, drilling, Milling and turning. Nine or ten videos:
    MIT TechTV ? Machine Shop 1
    For a simple project, make a Milling clamp with a serrated\step edge.
    Another simple project is to square up a metal cube or rectangle.
  1. Replies: 6
    Last Post: 07-04-2011, 01:46 AM
  2. training material EZ path
    By copperhead4321 in forum Uncategorised MetalWorking Machines
    Last Post: 07-05-2008, 02:25 PM
  3. Mastercam Wire Training Material
    By Steve Arteman in forum Mastercam
    Last Post: 08-31-2007, 08:45 PM
  4. need MasterCam Training material
    By kiethnt in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-29-2007, 06:51 PM
  5. Training Material
    By Metalizer in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-10-2005, 11:36 PM
