603,982 active members*
2,608 visitors online*
IndustryArena Forum > CAM Software > Mastercam > transform rotate
Results 1 to 6 of 6
    Dec 2011
    transform rotate
    why is 120 degrees the initial start angle and not 90 degrees?
    May 2004
    4519
    Why not use 0 degrees as initial start angle with 120 degrees incremental?
    Dec 2011
    Quote Originally Posted by txcncman View Post
    incremental does not appear to be a choice in x5 for transform rotate.
    May 2004
    4519
    Angle Between is the incremental. Angle Between 2 times. Angle between 7 times. How ever many.
    Dec 2011
    zero degrees reflects the toolpath i wish to transform regardless of where that toolpath resides in relation to a coordinate system?
    zero degrees means do not shift the initial toolpath i want to transform?
    Dec 2008
    3216
    It also depends on the use of subs, dis-allow posting of originals ( ghost ), copy.... blah blah
    you would then start at o°, & then pitch incremental ( be it transform or rotate )
    - this would mean that the original path is not in the main program, and the repeats ( 1st call would be at the place of programming )
    ----see what happens if you just post the transform operation ( play with the settings I've mentioned ), you can shorten a program quite considerably.
    You should do long programs if you are running the program in DNC ( drip) mode, as you cannot jump around program lines using this method
  1. x5 transform toolpath
    By Lafaso870 in forum Mastercam
    Last Post: 11-20-2010, 04:33 AM
  2. Transform in NX6
    By mongo46538 in forum UG NX
    Last Post: 12-16-2009, 04:27 PM
  3. Transform problem
    By mattpatt in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-07-2009, 09:01 AM
  4. Autobots, Transform!
    By Switcher in forum RC Robotics and Autonomous Robots
    Last Post: 07-13-2007, 12:48 PM
