606,815 active members*
4,014 visitors online*
Results 1 to 13 of 13
    Aug 2013
    11
    translations from german
    hi there!
    i have just a question, i have to translate into english these words related to industrial machinery but i cannot find the right translation
    Fenstermachine
    Fensterbaumachine
    leit- und zugspindeldrehmaschine
    absauganlage
    if you could help me, should be really appreciated
    thanks a lot
    Dec 2007
    362
    google translate was helpful
    Regards
    Geoff
    Aug 2013
    11
    yes, but at this point it was not. difference between fensterbaumachine and fenstermachine is quite slight and google cannot help me :-(
    same with portalkran. i do not know if in English it means overhead crane or Gantry crane
    tx
    May 2011
    Hello
    Well bau means Build so a Fensterbau Machine would be a machine that makes window frames and a portalkran is a Gantry crane.
    If you would like to give me a link to give I could check it out better.
    Are you ok one the other words?
    Regards
    Ian
    Aug 2013
    11
    hi! thanks for your answer. unfortunately i have no links, i have to translate those terms into English. what is the difference then between overhead crane and Gantry crane? i agree on fensterbaumachine's meaning but then fenstermachine, what does it mean? window machine? tx again, very appreciated
    Razastin Guest
    Hello caruana20,
    it is a little difficult to translate something like "Fenstermachine" or "Fensterbaumachine". Literally this word would mean something like "Window machinery". Maybe you can tell the meaning by describing like "I am looking for a machinery to produce windows..."?
    Leit- und Zugspindeldrehmaschine: screw cutting and bar lathe, horizontal turning machine
    Absauganlage: exhaust system, exhausting plant, suction plant or suction unit
    Aug 2013
    11
    hi! thanks a lot for your answers too. yes, i know it is difficult but i am pretty sure there are some differences between fenstermachine and fensterbaumachine but i cannot come accross the answer. as for the rest, u r right, tx again, very appreciated
    Feb 2009
    2143
    Translation needs context - it is not a 1:1 thing. Without more context/pictures/discussion you won't be able to improve the accuracy of the "guesses" of your translation....
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Aug 2013
    11
    hi! u are 100% right, but unfortunately i dont have them. i have just these 2 words to be translated with no context. thanks for your answer
    Aug 2013
    3
    What are the words you need translated. I will help you. I am a real Kraut
    Aug 2013
    3
    A fenster machine is a machine that makes windows the exact translation is window machinine. A fenster bau machine is basicly the same the exact thanslation is window building machine. Will that help you if not reply. Maby we will turn you into a kraut
    The word bau means building
    Aug 2013
    11
    hi! thanks a lot. these are Fernstermaschine and Fernsterbaumachine
    Aug 2013
    11
    ok, so, it is exactly the same
  1. Choosing between 3 german CNC routers
    By Paalm in forum Commercial CNC Wood Routers
    Last Post: 11-05-2019, 09:54 PM
  2. Anybody using German Cad/Cam software?
    By jamesweed in forum Uncategorised CAM Discussion
    Last Post: 07-17-2013, 07:23 PM
  3. LaserCut53.exe english translations
    By charliex in forum LaserCut
    Last Post: 06-15-2012, 09:35 PM
  4. german transaltion question
    By BMackinnon in forum Uncategorised CAM Discussion
    Last Post: 09-19-2006, 06:09 PM
  5. German certificate?
    By Alarm Hero in forum Employment Opportunity
    Last Post: 09-11-2006, 01:44 AM
