Hi I've been on here before asking questions about this mill TREE 310 dynapath 20. After searching old posts for info I'm wondering if the incoming power is connected correctly. Does anyone know which teminal the " wild" leg should be on I have 220 3 phase This mill did run at first then problems started with the crt not powering up. Now the crt is dead, spindle will run only if contacts are manually pushed in and power knee is the same. I have read about green lights lit on the cards but mine are all red. I don't have the schematics I do have the programming manuals When the crt did power awhile back it said battery needs replaced but if this thing is going to cost a bunch to get going its not worth it. Thanks in advance you guys helped me alot to get me started with the referencing the axis and such
