Hi, I am new to this forum but have gotten tons of good ideas from reading you guys over the last 6 months. Thanks. Here is my problem, I just boght a tree journeyman 310 mill with a dynapath delta 20 control. I ran the machine before I bought it in jog mode and all seemed fine. I ran the spindle speed up and down and ran all axes. again all fine. I then loaded it on a trailer and brought it home. After much coaxing i got it into the garage. I ran the power and turned it on. Again all fine. I referenced the axes. Jogged the axes, fine. Now for the problem. As soon as I start the spindle the whole machine including the control shuts down. I am running everything off a 10hp rotary converter. I thought that maybe it was pulling too much voltage when the motor started up so I ran a seperate 220v supply to the control box for power. Tried running the machine again, same problem. It seems that it is tripping something in the control box and shutting everything down. I am sure i am just missing something. It is a variable speed spindle but that is not controlled by the computer it is manual. If I turn the spindle speed down it takes a bit longer before it shuts everything down, but only 10-15 seconds. I have been messing with everything for 2 days now and am at my witts end. Any help would be much appreciated. The machine is set up 230v 3 phase. Thanks in advance.![]()
