603,900 active members*
2,910 visitors online*
IndustryArena Forum > CAD Software > Rhino 3D > trouble saving rhino file to useable DXF
    Apr 2005
    61
    Question trouble saving rhino file to useable DXF
    I'm in rhino and i have an outline of a panther that i want to cut on cnc router using deskcnc. I am able to save the file as dxf and i am able to open it in deskcnc but only some of the outlines in the panthers face will be as closed islands and most will be open enties. Yet when i go back to rhino all the lines are closed. What am I doing wrong? Thanks Brady
    Sep 2006
    43
    Brady,
    When you save as a DXF there are many options to set that will affect the way the file is translated to DXF. Play with them and I am sure you will find a way to get it to output what you need. When exporting a window will pop up that asks what format. Hit thed edit schemes tab and output all geometry as polylines. I think that will work for you.
    GOOD LUCK !!!!
    Quote Originally Posted by bradyfb View Post
  1. Rhino Toolbar default file
    By flat6turboGT1 in forum Rhino 3D
    Last Post: 03-14-2009, 02:50 PM
  2. Saving a file
    By bjm323 in forum Mastercam
    Last Post: 11-23-2008, 06:22 PM
  3. Saving file
    Last Post: 10-16-2008, 12:05 AM
  4. Saving a File
    By utahnorton in forum Centroid CNC Control Products
    Last Post: 12-29-2006, 04:10 AM
  5. Saving a Text file?
    By Scott V in forum BobCad-Cam
    Last Post: 11-24-2004, 03:27 AM
