587,174 active members*
3,422 visitors online*
Results 1 to 7 of 7
    Mar 2006
    92
    Troubleshoot DNC
    I'm trying drip feed to a Lagunamatic 3 axis mill with a desktop PC. I have the serial connection hooked up. Mastercam is sending the programs, but the controller says it doesn't have communication. It's a Dynapath controller. Any tips?
    phoodieman
    Sep 2006
    24
    comm ports
    First thing I would check is to be sure your comm ports are set the same on both cnc and pc
    Apr 2003
    348
    Is the controller set in the rs232c mode?
    Sep 2006
    222
    Cable problem ?
    Please check: cadem.com
    Mar 2006
    92
    Cable is good. Pinout is right. The controller is ready. I think it might be settings in the PC, but everything seems to be right. I'm stuck.....
    Phoodieman
    Apr 2003
    348
    Is it a Dynapath 20 controller?
    Oct 2005
    22
    Do you load your programs using this desktop?
