586,068 active members*
4,238 visitors online*
Results 1 to 8 of 8
    Nov 2013
    Trumpf 3030 Reference Autolas error!!! HELP!!
    Morning folks. I operate a Trumpf 3030 laser and when I cycle start any program I get error PLC(80.110050) Reference Autolas (1) not reached....Can anyone help me with this problem?? I dont know much as far as maitenance goes. It says cause could be lanny valve faulty, filter soiled....says check 8bit supply line to lanny??? and check the filter. I just dont know what that means or where the filter is. any input would to helpful. Its a new machine, only been running about 4 months.
    THANKS!
    Nov 2013
    our trulaser 2030 had a very similair error our operator located the lanny valve in the top of the head shroud im not sure of the exact location but he explained that the lanny valve regulates pressure to the focusing mirror therefore it must be in a water supply line and be near the beam path, after removing the part and clearing the valve with shop air the machine was re-assembled without further incident
    Dec 2013
    3
    Do not worry about it. It's just the automatic focus setter. It's works when this error appear. The only thing that harder to go to menu.
    How to improve hello to me what the error is the ENCODER defective help
    İngilizce Türkçe Cümle Çeviri | İngilizce Türkçe Sözlük | ÇevirSözlük.com trumpf 1997 eror
    error code please
    trumpf 1997 eror
    Jun 2019
    3
    Arapça çeviri,rusça çeviri,almanca çeviri,Kürtçe Çeviri,metin çeviri,cümler çeviri,ingilizce çeviri,dil çeviri işlemlerini en doğru,hızlı ve güvenilir bir şekilde yapabilirsiniz.
    cümle çeviri / Kürtçe Çeviri / İngilizce Türkçe Çeviri / Türkçe İngilizce Çeviri / Metin Çeviri
    Jun 2019
    3
    Jun 2019
    3
    Türkçeden özbekçeye,özbekçeden Türkçeye çeviri yapmak istiyorsanız özbekçe çeviri adresinden hızlı ve doğru bir şekilde metin ve cümle çevirinizi yapabilirsiniz.
  1. missing tech tables for a 3kw Trumpf 3030
    By Groo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-14-2017, 04:37 AM
  2. Trumpf 3030
    By carl_ray88 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-07-2015, 10:19 AM
  3. Bulletin fpm2813 reference error
    By Cnc an in forum CNC Machining Centers
    Last Post: 07-19-2012, 11:00 AM
