603,940 active members*
2,004 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Trying to add rotory axis, need help.
    Mar 2006
    233
    Howdy again! its been a while and Ive got a new obstacle Im trying to overcome. Im trying to add a rotary axis to my DIY machine, Let me give yall the rundown of what I have and what I am thinking and yall can help me from there.
    My 3 axis machine is using g540 / uc100 / mach 3 and currently has the "A" axis slaved to the "Y" stepper for dual lead screws on the Y axis. This obviously uses up all 4 outlets on the G540. I am very happy with the machines current performance and setup and am not looking to overhaul my motion control setup.
    I was poking around trying to see if it was going to be possible at all to achieve what I am wanting and someone had recommended to put this....
    https://czh-labs.com/czh-labs-din-ra...RoCtjAQAvD_BwE
    ... in between the uc100 and the g540. This would allow me to tap the pins before it gets to the g540 and I could add a single g250x or g251x driver for the rotary axis. I could then create a profile in mach just for the rotory in mach when I want to use it.
    Any ideas?
    Jan 2006
    738
    Re: Trying to add rotory axis, need help.
    Yes that should allow you to tap off and isolate 2 pins for step and dir for the 4th axis, as well as tapping into an enable pin if used. Nice looking machine!
  1. using 4th axis or rotory indexer
    By Gallchobhair in forum BobCad-Cam
    Last Post: 04-24-2014, 10:11 PM
  2. Rotory table
    By alc2304 in forum Want To Buy...Need help!
    Last Post: 06-28-2012, 02:14 PM
  3. contour on 4th rotory
    By metlshpr in forum Mastercam
    Last Post: 01-03-2011, 03:47 PM
  4. 4th Axis Rotory Tables
    By no1rider in forum Haas Mills
    Last Post: 09-22-2009, 01:30 AM
  5. Interested in adding 4th (rotory) axis - need help
    By Hack in forum DIY CNC Router Table Machines
    Last Post: 06-25-2005, 04:28 PM
