603,894 active members*
4,743 visitors online*
Page 1 of 2 12
Results 1 to 20 of 32
    Nov 2009
    12
    Trying to choose...
    I need a light production cnc with 20" travel in X. I will be doing a lot of drilling in light aluminum so decent rapid moves would cut down cycle times. Other runs are some aluminum billet machining, no real tough materials.
    I would like to spend $10000+- but need an easy turnkey. I like Microkinetics cnc express, IH turnkey, and smithy 1240 bed mills.
    http://www.ihcnc.com/pages/cnc-mill.php
    http://www.microkinetics.com/express/
    http://www.smithy.com/products.php?cid=11
    Any info to steer me would be appreciated.
    Sep 2006
    1738
    If looking at the Smithy, look to Novakon instead. Same machine, but I hear there is more support from them. If you are a student they also give a 15% discount so you save a few thousand dollars.
    -Jason
    Mar 2008
    3655
    Hi CPK. Welcome to the Zone!
    Quote Originally Posted by SpeedsCustom View Post
    If looking at the Smithy, look to Novakon instead. Same machine, but I hear there is more support from them. If you are a student they also give a 15% discount so you save a few thousand dollars.-Jason
    Good choice Jason, but that will not give him 20 inches X travel.
    Now I would build that with an X3 head/column mated to a Grizzly G1006 base and table--23 inches of X, but you need a turnkey.
    Even the Tormach 1100 won't have 20 inches of X.
    Looks to me like the IH would be the best bet:
    CR.
    Feb 2006
    7063
    If you can get by with just a little less than 20" X travel, I'd take a serious look at the Mikini Mechatronics 1620L. It looks like a *really* nice machine for the money, and will save you the trouble and expense of building an enclosure, electronics, etc., etc.. Just pluig it in and get right to work.
    Regards,
    Ray L.
    Jul 2007
    1602
    The Novakon NM 200 claims 24" X travel so would cover that aspect. Rapids are only about 100 ipm so that might not be optimal.
    Mar 2008
    3655
    Quote Originally Posted by HimyKabibble View Post
    Regards,
    Ray L.
    Looks like a nice machine all right, but only 16 inches X. Is this even available yet?
    http://www.prlog.org/10217120-mikini...operation.html
    CR.
    Mar 2008
    3655
    Quote Originally Posted by rowbare View Post
    Oops! Forgot about the Novakon 200. Sorry Jason, you were right.
    CR.
    Nov 2009
    12
    Close
    The Mikini is my first choice. I even called them, but then realized I needed more travel. I could get by with 19 minimum, so I am looking for second best.
    Feb 2006
    7063
    Quote Originally Posted by Crevice Reamer View Post
    CR.
    I don't know for certain, but they're website certainly makes it seem that it is. They're just down the road from me. I'll have to go visit them sometime. Were I buying a machine right now, that's the one I'd be looking at, even though it's smaller than my knee mill, it would do 99% of what I need, and looks to be a very nice machine.
    Regards,
    Ray L.
    Mar 2008
    3655
    ...and looks to be a very nice machine.
    Ray L.
    Indeed!
    CR.
    Nov 2009
    12
    Microkinetics
    Any info on the microkinetics?
    Here's a new mill to take a look at, the BobMill 2300-MK 2 turnkey.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Feb 2006
    7063
    Quote Originally Posted by cpkids View Post
    The 1600 RPM max. spindle speed will absolutely kill you working in aluminum. I would consider 5K an absolute minimum. Mine runs 8200RPM, and that still limits how fast I can go with anything but larger cutters (1/2" and larger).
    Regards,
    Ray L.
    Nov 2009
    12
    Quote Originally Posted by hoss2006 View Post
    Hoss
    Wow! what a great machine. It would be great but at $14999 it is 50% over budget. Now I am going to hate whatever I get as inadequate.
    Mar 2008
    3655
    Here's a benchtop mill comparison chart:
    http://novakon.net/resources/NM-200+Compare.pdf
    The Novakon NM-200 does look like the most economical choice:
    http://novakon.net/3.html
    CR.
    Sep 2006
    1738
    Personally the Novakon is going to be my choice when it comes to a new mill. It also has a very nice Y travel that all other mills in this category lack.
    Don't worry CR!
    -Jason
  17. #17
    Nov 2009
    12
    novakon
    The novakon has a bad rep from another thread on this forum. Makes me a little gun shy. Seems like you can't use the speed because it is not solid enough.
    http://www.cnczone.com/forums/showth...t=78418&page=2
    "the column is not completely stable. Don't get me wrong, it's a fantastic mill for the price range, but when going to feed rates above around 10 or 15 and when there is a lot of rapid x and/or y movement"
  18. #18
    Nov 2009
    12
    Game over
    I submitted a request for the Bobmill 2300MK2 as a dream request. Approved. I get it all. $15845 to my door.
  19. #19
    Maybe they'll take $10,000 down and $20 a month.
    Do they offer leasing?
    Hoss
  20. #20
    Nov 2009
    12
    A big thanks to Hoss for pointing out the Bobmill 2300 system. It is new on the market, but seems to fit my needs well. It is a little more than I initially wanted, but 3 times the machine.
    We are just writing a check. Don't think they offer financing. If you want to call them talk to Al. He helped me.
    I will post some pics when I get the box.
Page 1 of 2 12
  1. which one to choose
    By cncsdr in forum Uncategorised MetalWorking Machines
    Last Post: 09-12-2009, 12:23 AM
  2. Need help to choose
    By IN-WondeR in forum Servo Motors / Drives
    Last Post: 08-22-2007, 06:59 AM
  3. help me to choose...
    By serankko in forum Uncategorised CAM Discussion
    Last Post: 02-05-2007, 06:02 PM
  4. What shall I choose ?
    By NitroXide in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-15-2007, 02:19 PM
