588,563 active members*
4,975 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Multicam Machines > trying to cut 241 inches on multicam 3000 with 240 inches of travel
Results 1 to 4 of 4
    Apr 2015
    3
    Does anyone know the parameter nuber that will allow me to change my cut length so i can 241 when it is normally set to 240...without a cut stretcher.
    Jan 2008
    35
    Re: trying to cut 241 inches on multicam 3000 with 240 inches of travel
    did you make any progress jet ?
    first thing to do is to get a backup of the flashram.uc file (User Init File) an date it
    shift + F2 in motion mechanic
    like : 2015-04-10_flashram.uc
    this is how I handle al the files I make
    open this in notepad or any plain text editor (notepad ++ is my favourite ! )
    and look for any number in the order of 240
    it could well be param 5 and 9 ( 6 and 10 for Y)
    supposing MC is still using the same (main) parameters
    X-Axis Negative Stroke 5 F Negative Distance from X-Axis Limit Offset.
    X-Axis Table Size 9 F Positve Travel Distance from X-Axis Limit Offset
    this is how you enter (you're number) in motion mechanic
    3125.000000 9 set_float
    ( mm's in my case )
    Jan 2008
    35
    Quote Originally Posted by shawnski View Post
    can you tell what that is please
    Apr 2015
    3
    Quote Originally Posted by keesfrees View Post
    thanks for your help!
    a cut stretcher is just like a board stretcher, if you need a board at 99 inches instead of the 96 or 98" one you have, you just stick it in the board stretcher to make it 99" and your good. its like that but with a cut.
  1. Need about 4 more inches
    By br1 in forum Mori Seiki Mills
    Last Post: 11-20-2012, 09:24 PM
  2. Add some inches to Joe CNC 06 R2
    By vickuaeh in forum CNC Wood Router Project Log
    Last Post: 07-25-2012, 10:26 PM
  3. metric to inches
    By cinci5 in forum Mastercam
    Last Post: 03-21-2009, 01:19 PM
  4. To Be or not To Be in Inches
    By weirdharold in forum UG NX
    Last Post: 01-22-2009, 04:30 PM
  5. Inches and mm
    By jorgehrr in forum Solidworks
    Last Post: 02-04-2008, 10:43 PM
