Okay, for those of you that have asked it has finally been released. For details please click on the link.
http://www.haascnc.com/LATHE_MODEL_S...LatheTreeModel
Haas Apps,
May I ask the purpose of the SS-30 and ST-30? Are these machines going to replace the SL-30 platform or just a higher performance version in the 3" bar range? I was hoping that the SL-30 platform would be revamped instead of a new and shorter model. I always found the Sl-30 turret to be too small especially for oilfield work. Running devibe bars pose a ton of problems due to the turret size. Over a year and a half ago I heard stories that a new machine was coming out so I waited and waited until I had no choice but to order machines. I bought a Mori NL-3000Y/1250 and a NL-2500SY/700 instead of a SL-30L BB , SL-30, and 2 VF-3/40's to complement my 3 existing Haas machines. Those 3 Haas machines have made a lot of parts and made a lot of money with very little on the maintenance end. The control is a standout feature. Easy transition from machine to machine and year model to year model. While MAPPS 3 is much more advanced than the Haas control, I still find some features easier to use on the Haas than the Mori.
My biggest complaint regarding Haas and specifically the SL lathe line up is it seems to be a compromise between price and performace rather than building an "American" lathe to compete against the Mori NL's or Doosan or even Mazak. I still think the perfect Mazak belongs on the end of an anchor chain, but that is another story.
I am not saying that I will not buy another SL-30 or even a SS/ST-30(haven't seen one in person yet) but in my opinion the SL series could be improved greatly. I realize there are other factors that must be accounted for but "I" would build a "no compromise" machine rather than a good machine. And again, my opinion, a live tooling machine is useless without Y axis. Interpolating will only get you so far. What happened to the SL-30Y that was at Westec in 2006?
Well, as you may know I am the Applications Manager and may not be able to answer all of your questions, but I will make an attempt.
The SS/ST line is a completely new model. It was designed from the ground up to be a robust machine. We have spent the better part of the last four years working on these machines and are very confident in their performance. I have had my staff testing these machine for about three years now and we are happy with the results. The turret on the SS/ST is much larger than the SL series and can accommodate up to 24 tools (yes 24). That should give you an indication of the turret size.
As you can probably guess I can not really discuss some of the things we have in development. But as many know Haas continues development of all our models all the time.
Haas Apps,
Do you have a better picture of the 24 poition turret? The data sheet does not show it well.
I have looked and can not find any. I will ask around.
Haas Apps: Could you please tell me why the Office mills are so expensive. A Super Minimill 2 is the same price as the smaller Office mill. This is puzzling.
Thanks.
How is it more robust? The SS/ST looks a little taller but are how they more robust than a SL30? and what sets them apart other than a slightly larger size? Is the SS/ST something to replace the SL series or is it an addition to lathe series? I'm still in the toolroom lathe phase but I'm curious.
John,
The SS/ST line is a new lathe line. It is not a replacement for anything. Aside from the 24 tools, faster rapids, and spindle speeds, the overall design of the machine is outstanding. If you want to do a side-by-side comparison just go to:http://www.haascnc.com/specs.asp?ID=...LatheTreeModel and then select the SS-30 and ST-30 to compare specs.
