603,979 active members*
1,457 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > trying to enable Macro B on a Fanuc 6m on a machine center
Results 1 to 5 of 5
    May 2020
    11
    i am trying to turn macro b on on an older Matsuura.
    i tried to turn parameter 300 bits 1 and 3 to a 1.
    i am in mdi
    i have the parameter enable switch flipped.
    i am able to change it, but when i flip the switch back and restart the control it reverts back to a 0.
    am i doing something wrong or out of sequence?
    i am open to any and all suggestions. if you need more info just let me know.
    thx
    Apr 2009
    1401
    Re: trying to enable Macro B on a Fanuc 6m on a machine center
    Your software may not support that option; what is the software edition?
    May 2020
    11
    System: 6M
    Series: M01
    Version:07
    May 2020
    11
    can anyone let me know what rom chips and software i would need to enable macros?
    thx
    Oct 2024
    6
    Flip the Parameter Write Enable (PWE) switch to ON.
    Go to Parameter 300, and set Bit 3 (Macro B) to 1.
    Confirm the changes by pressing the Input or Write key.
    Flip the PWE switch back to OFF.
    Power off the machine using the proper shutdown procedure.
    Restart the machine to ensure the changes persist.
    print shop near me
    print shop near me
    May 2020
    11
    so i must have hit the wrong button the first time i tried to enabled macro b.
    i now have P300 B3 as a 1 after restarting the machine, but when i try to use the inc/abs button as a shift key it is not working. is there anything additional to make the inc/abs button to act like shift? or is there a way to test that macro b is in fact working?
    thx
