With Al_the_Man's help I've managed to wire up my SIEMENS servo motor to a RuteX drive (drive pooped so now I've got a CNC TekniX T20 drive), I had the motor moving back and forth, reasonably smooth and then it tripped the drive so I reset it and it didn't matter what setting I used in Mach 3 it just wouldn't move without tripping the drive out.
Because this drive is tuned manually with a screw driver, I wrote a program in Mach3 to go back and forth, I thought I would just tune the drive manually whilst in motion, but everytime I turn the P pot up it trips out the drive (even if I turn it 1 degree) (Both I & D are turned all the way down at this stage).
Can I use different software to move the motor back and forth to tune it, just so I can eleminate Mach 3 settings as my problem?
Also because I had the motor moving (it was moving quite fast actually) does that mean it is definately wired correctly? In other words if the encoder was wired incorrectly e.g A,A/,B,B/,I,I/ Would it still move?
I have checked these wires over and over again, but it all seems o.k.
It seems like it's so close to working...........this machine is a tease!
