587,760 active members*
2,753 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Trying to understand g-code from toopath
Results 1 to 5 of 5
    Feb 2012
    23
    Hi there,
    I'm just wondering about why the g-code below has been generated with regard to the toolpath? I ahve attched a screenshot of the toolpath.
    In the pocketing screen in MadCam the top of the material is set at 0 and the bottom at -5. I move the tool to the corner of the material and zero coordinates in Mach3.
    When the program starts, it moves to the center of the circle and plunges down, as I think is defined in the g-code below as z13.000. A circle is created, but the tool seems to plunge in first (way to deep) and then on ocassion do a cutting spirial where it is cutting air - it's like it's doing the toolpath in reverse.
    I am relatively new to g-code and CNC, so someone more experienced may just be able to state the obvious - I am hoping so!
    Cheers,
    Hamish
    Ocircle2
    G40 G54 G80 G90
    (HD cutter 1)
    M06 T1
    S4000 F350 M03
    G43 H1
    G00 X32.06526 Y30.50837
    Z13.00000
    G01 Z10.01267 F350
    X31.80514 Y30.99461 Z9.91543 F350
    X31.62843 Y31.17133 Z9.87137
    X30.77736 Y31.62661 Z9.70118
    X29.92630 Z9.55111
    X29.07523 Y31.17132 Z9.38092
    X28.89853 Y30.99461 Z9.33686
    X28.44323 Y30.14355 Z9.16667
    Y29.29249
    X28.89853 Y28.44142
    X29.07523 Y28.26471
    X29.92630 Y27.80942
    X30.77736
    X31.62843 Y28.26471
    X31.80514 Y28.44142
    X32.26043 Y29.29249
    Y30.14355
    X31.80514 Y30.99461
    X31.62843 Y31.17133
    X30.77736 Y31.62661
    X29.92630
    X29.07523 Y31.17132
    X28.89853 Y30.99461
    X28.44323 Y30.14355
    X26.99227 Y30.56908
    X25.54131 Y30.99461
    X25.40499 Y30.14355
    Y29.29249
    X25.54131 Y28.44142
    X25.67098 Y28.06660
    X25.86021 Y27.59036
    X26.38199 Y26.73929
    X26.52204 Y26.57526
    X27.20907 Y25.88823
    X27.37311 Y25.74817
    X28.22417 Y25.22640
    X28.70041 Y25.03717
    X29.07523 Y24.90750
    X29.92630 Y24.77118
    X30.77736
    X31.62843 Y24.90750
    X32.00325 Y25.03717
    X32.47949 Y25.22640
    X33.33055 Y25.74817
    X33.49459 Y25.88823
    X34.18162 Y26.57526
    X34.32167 Y26.73929
    X34.84344 Y27.59036
    X35.03268 Y28.06660
    X35.16235 Y28.44142
    X35.29866 Y29.29249
    Y30.14355
    X35.16235 Y30.99461
    X35.03268 Y31.36944
    X34.84344 Y31.84568
    X34.32167 Y32.69674
    X34.18162 Y32.86077
    X33.49459 Y33.54781
    X33.33055 Y33.68786
    X32.47949 Y34.20963
    X32.00325 Y34.39887
    X31.62843 Y34.52854
    X30.77736 Y34.66485
    X29.92630
    X29.07523 Y34.52854
    X28.70041 Y34.39887
    X28.22417 Y34.20964
    X27.37311 Y33.68786
    X27.20907 Y33.54781
    X26.52204 Y32.86077
    X26.38199 Y32.69674
    X25.86021 Y31.84568
    X25.67098 Y31.36944
    X25.54131 Y30.99461
    X24.09682 Y31.42015
    X22.65234 Y31.84568
    X22.48139 Y30.99461
    X22.38634 Y30.14355
    Y29.29249
    X22.48139 Y28.44142
    X22.65233 Y27.59036
    X22.96124 Y26.73929
    X23.11779 Y26.36845
    X23.35484 Y25.88823
    X23.89594 Y25.03717
    X23.96885 Y24.94545
    X24.61721 Y24.18610
    X24.81991 Y23.98339
    X25.57926 Y23.33504
    X25.67098 Y23.26213
    X26.52204 Y22.72102
    X27.00226 Y22.48397
    X27.37311 Y22.32743
    X28.22417 Y22.01852
    X29.07523 Y21.84758
    X29.92630 Y21.75253
    X30.77736
    X31.62843 Y21.84758
    X32.47949 Y22.01852
    X33.33055 Y22.32743
    X33.70140 Y22.48397
    X34.18162 Y22.72102
    X35.03268 Y23.26213
    X35.12440 Y23.33504
    X35.88374 Y23.98339
    X36.08645 Y24.18610
    X36.73481 Y24.94545
    X36.80772 Y25.03717
    X37.34883 Y25.88823
    X37.58587 Y26.36845
    X37.74242 Y26.73929
    X38.05133 Y27.59036
    X38.22227 Y28.44142
    X38.31731 Y29.29249
    Y30.14355
    X38.22227 Y30.99461
    X38.05132 Y31.84568
    X37.74242 Y32.69674
    X37.58587 Y33.06758
    X37.34882 Y33.54781
    X36.80772 Y34.39887
    X36.73481 Y34.49058
    X36.08646 Y35.24993
    X35.88374 Y35.45265
    X35.12439 Y36.10100
    X35.03268 Y36.17391
    X34.18162 Y36.71501
    X33.70140 Y36.95206
    X33.33055 Y37.10861
    X32.47949 Y37.41751
    X31.62843 Y37.58846
    X30.77736 Y37.68350
    X29.92630
    X29.07523 Y37.58846
    X28.22417 Y37.41751
    X27.37311 Y37.10861
    X27.00225 Y36.95206
    X26.52204 Y36.71502
    X25.67098 Y36.17391
    X25.57926 Y36.10100
    X24.81991 Y35.45264
    X24.61721 Y35.24993
    X23.96885 Y34.49058
    X23.89594 Y34.39887
    X23.35484 Y33.54781
    X23.11779 Y33.06758
    X22.96124 Y32.69674
    X22.65234 Y31.84568
    X21.18293 Y32.15258
    X19.71353 Y32.45948
    X19.57703 Y31.84568
    X19.44609 Y30.99461
    X19.37626 Y30.14355
    Y29.29249
    X19.44609 Y28.44142
    X19.57703 Y27.59036
    X19.71353 Y26.97655
    X19.77269 Y26.73929
    X20.06416 Y25.88823
    X20.42342 Y25.03717
    X20.56460 Y24.73623
    X20.86721 Y24.18610
    X21.41661 Y23.33504
    X22.09319 Y22.48397
    X22.26672 Y22.29394
    X22.92776 Y21.63291
    X23.11779 Y21.45938
    X23.96885 Y20.78280
    X24.81991 Y20.23340
    X25.37004 Y19.93078
    X25.67098 Y19.78961
    X26.52204 Y19.43034
    X27.37311 Y19.13888
    X27.61036 Y19.07972
    X28.22417 Y18.94322
    X29.07523 Y18.81228
    X29.92630 Y18.74245
    X30.77736
    X31.62843 Y18.81228
    X32.47949 Y18.94322
    X33.09329 Y19.07972
    X33.33055 Y19.13888
    X34.18162 Y19.43035
    X35.03268 Y19.78961
    X35.33361 Y19.93078
    X35.88374 Y20.23340
    X36.73481 Y20.78280
    X37.58587 Y21.45938
    X37.77590 Y21.63291
    X38.43694 Y22.29394
    X38.61047 Y22.48397
    X39.28800 Y23.33628
    X39.83645 Y24.18610
    X40.13906 Y24.73623
    X40.28024 Y25.03717
    X40.63950 Y25.88823
    X40.93097 Y26.73929
    X40.99013 Y26.97655
    X41.12662 Y27.59036
    X41.25757 Y28.44142
    X41.32740 Y29.29249
    Y30.14355
    X41.25757 Y30.99461
    X41.12663 Y31.84568
    X40.99013 Y32.45948
    X40.93097 Y32.69674
    X40.63950 Y33.54781
    X40.28024 Y34.39887
    X40.13906 Y34.69979
    X39.83644 Y35.24993
    X39.28704 Y36.10100
    X38.61047 Y36.95206
    X38.43694 Y37.14209
    X37.77591 Y37.80312
    X37.58587 Y37.97666
    X36.73357 Y38.65419
    X35.88374 Y39.20263
    X35.33361 Y39.50525
    X35.03268 Y39.64642
    X34.18162 Y40.00569
    X33.33055 Y40.29716
    X33.09329 Y40.35632
    X32.47949 Y40.49281
    X31.62843 Y40.62376
    X30.77736 Y40.69358
    X29.92630
    X29.07523 Y40.62376
    X28.22417 Y40.49281
    X27.61036 Y40.35632
    X27.37311 Y40.29716
    X26.52204 Y40.00569
    X25.67098 Y39.64643
    X25.37005 Y39.50525
    X24.81991 Y39.20264
    X23.96885 Y38.65324
    X23.11779 Y37.97666
    X22.92776 Y37.80312
    X22.26672 Y37.14209
    X22.09319 Y36.95206
    X21.41566 Y36.09975
    X20.86721 Y35.24993
    X20.56460 Y34.69980
    X20.42342 Y34.39887
    X20.06416 Y33.54781
    X19.77269 Y32.69674
    X19.71353 Y32.45948
    X18.30329 Y33.00364
    X16.89304 Y33.54781
    X16.68084 Y32.69674
    X16.53072 Y31.84568
    X16.42148 Y30.99461
    X16.37099 Y30.14355
    Y29.29249
    X16.42148 Y28.44142
    X16.53071 Y27.59036
    X16.68084 Y26.73929
    X16.89304 Y25.88823
    X17.17558 Y25.03717
    X17.50897 Y24.18610
    X17.90822 Y23.33504
    X18.01140 Y23.13315
    X18.38566 Y22.48397
    X18.86247 Y21.73985
    X19.59329 Y20.78185
    X19.71353 Y20.64098
    X20.36207 Y19.93078
    X20.56460 Y19.72826
    X21.27479 Y19.07972
    X21.41566 Y18.95948
    X22.37366 Y18.22866
    X23.11779 Y17.75185
    X23.76696 Y17.37759
    X23.96885 Y17.27440
    X24.81991 Y16.87515
    X25.71162 Y16.52653
    X26.52204 Y16.25923
    X27.37311 Y16.04703
    X28.22417 Y15.89690
    X29.07523 Y15.78767
    X29.92630 Y15.73717
    X30.77736
    X31.62843 Y15.78767
    X32.47949 Y15.89690
    X33.33055 Y16.04703
    X34.18162 Y16.25923
    X35.03268 Y16.54176
    X35.88374 Y16.87515
    X36.73481 Y17.27440
    X36.93670 Y17.37759
    X37.58587 Y17.75185
    X38.33000 Y18.22866
    X39.28800 Y18.95947
    X39.42887 Y19.07972
    X40.13906 Y19.72826
    X40.34159 Y19.93078
    X40.99013 Y20.64098
    X41.11037 Y20.78185
    X41.84119 Y21.73985
    X42.31800 Y22.48397
    X42.69226 Y23.13316
    X42.79544 Y23.33504
    X43.19469 Y24.18610
    X43.54332 Y25.07780
    X43.81062 Y25.88823
    X44.02281 Y26.73929
    X44.17294 Y27.59036
    X44.28218 Y28.44142
    X44.33267 Y29.29249
    Y30.14355
    X44.28218 Y30.99461
    X44.17294 Y31.84568
    X44.02282 Y32.69674
    X43.81062 Y33.54781
    X43.52808 Y34.39887
    X43.19469 Y35.24993
    X42.79544 Y36.10100
    X42.69226 Y36.30287
    X42.31799 Y36.95206
    X41.84119 Y37.69619
    X41.11037 Y38.65419
    X40.99013 Y38.79506
    X40.34159 Y39.50525
    X40.13906 Y39.70778
    X39.42887 Y40.35632
    X39.28800 Y40.47656
    X38.33000 Y41.20738
    X37.58587 Y41.68418
    X36.93668 Y42.05844
    X36.73481 Y42.16163
    X35.88374 Y42.56088
    X34.99204 Y42.90951
    X34.18162 Y43.17680
    X33.33055 Y43.38900
    X32.47949 Y43.53913
    X31.62843 Y43.64837
    X30.77736 Y43.69886
    X29.92630
    X29.07523 Y43.64837
    X28.22417 Y43.53913
    X27.37311 Y43.38900
    X26.52204 Y43.17681
    X25.67098 Y42.89427
    X24.81991 Y42.56088
    X23.96885 Y42.16163
    X23.76697 Y42.05844
    X23.11779 Y41.68419
    X22.37366 Y41.20738
    X21.41566 Y40.47656
    X21.27479 Y40.35632
    X20.56460 Y39.70778
    X20.36207 Y39.50525
    X19.71353 Y38.79506
    X19.59329 Y38.65419
    X18.86247 Y37.69619
    X18.38566 Y36.95206
    X18.01140 Y36.30288
    X17.90822 Y36.10100
    X17.50897 Y35.24993
    X17.16034 Y34.35823
    X16.89304 Y33.54781
    X15.46228 Y34.00869
    X14.03151 Y34.46957
    X13.72725 Y33.26149
    X13.51590 Y32.06058
    X13.39312 Y30.87617
    X13.35358 Y29.71796
    X13.39134 Y28.55968
    X13.51405 Y27.37514
    X13.72533 Y26.17406
    X14.02956 Y24.96581
    X14.42981 Y23.76073
    X14.92769 Y22.56988
    X15.52310 Y21.40485
    X16.21415 Y20.27736
    X16.99707 Y19.19897
    X17.86628 Y18.18064
    X18.81446 Y17.23247
    X19.83278 Y16.36326
    X20.91117 Y15.58034
    X22.03866 Y14.88929
    X23.20369 Y14.29388
    X24.39454 Y13.79600
    X25.59963 Y13.39575
    X26.80787 Y13.09152
    X28.00895 Y12.88024
    X29.19349 Y12.75753
    X30.35183 Y12.71802
    X31.51017 Y12.75753
    X32.69471 Y12.88024
    X33.89579 Y13.09152
    X35.10403 Y13.39575
    X36.30913 Y13.79600
    X37.49996 Y14.29387
    X38.66499 Y14.88929
    X39.79248 Y15.58034
    X40.87089 Y16.36326
    X41.88920 Y17.23247
    X42.83739 Y18.18064
    X43.70482 Y19.20047
    X44.48766 Y20.27871
    X45.17864 Y21.40602
    X45.77402 Y22.57088
    X46.27189 Y23.76155
    X46.67215 Y24.96646
    X46.97641 Y26.17454
    X47.18776 Y27.37547
    X47.31054 Y28.55986
    X47.35008 Y29.71807
    X47.31052 Y30.87630
    X47.18774 Y32.06070
    X46.97638 Y33.26163
    X46.67211 Y34.46973
    X46.27183 Y35.67464
    X45.77395 Y36.86531
    X45.17856 Y38.03016
    X44.48756 Y39.15748
    X43.70471 Y40.23571
    X42.83561 Y41.25389
    X41.88756 Y42.20193
    X40.86938 Y43.07101
    X39.79115 Y43.85384
    X38.66382 Y44.54483
    X37.49896 Y45.14021
    X36.30830 Y45.63808
    X35.10339 Y46.03834
    X33.89530 Y46.34260
    X32.69439 Y46.55395
    X31.50999 Y46.67672
    X30.35177 Y46.71627
    X29.19356 Y46.67671
    X28.00914 Y46.55392
    X26.80821 Y46.34257
    X25.60013 Y46.03830
    X24.39521 Y45.63802
    X23.20454 Y45.14014
    X22.03968 Y44.54475
    X20.91237 Y43.85375
    X19.83414 Y43.07090
    X18.81597 Y42.20180
    X17.86793 Y41.25375
    X16.99883 Y40.23557
    X16.21600 Y39.15733
    X15.52501 Y38.03001
    X14.92964 Y36.86515
    X14.43178 Y35.67449
    X14.03151 Y34.46957
    G00 Z13.00000
    Z12.17933
    G01 Z9.17933 F350
    X31.80514 Y30.99461 Z9.08210 F350
    X31.62843 Y31.17133 Z9.03803
    X30.77736 Y31.62661 Z8.86784
    X29.92630 Z8.71778
    X29.07523 Y31.17132 Z8.54759
    X28.89853 Y30.99461 Z8.50352
    X28.44323 Y30.14355 Z8.33333
    Y29.29249
    X28.89853 Y28.44142
    X29.07523 Y28.26471
    X29.92630 Y27.80942
    X30.77736
    X31.62843 Y28.26471
    X31.80514 Y28.44142
    X32.26043 Y29.29249
    Y30.14355
    X31.80514 Y30.99461
    X31.62843 Y31.17133
    X30.77736 Y31.62661
    X29.92630
    X29.07523 Y31.17132
    X28.89853 Y30.99461
    X28.44323 Y30.14355
    X26.99227 Y30.56908
    X25.54131 Y30.99461
    X25.40499 Y30.14355
    Y29.29249
    X25.54131 Y28.44142
    X25.67098 Y28.06660
    X25.86021 Y27.59036
    X26.38199 Y26.73929
    X26.52204 Y26.57526
    X27.20907 Y25.88823
    X27.37311 Y25.74817
    X28.22417 Y25.22640
    X28.70041 Y25.03717
    X29.07523 Y24.90750
    X29.92630 Y24.77118
    X30.77736
    X31.62843 Y24.90750
    X32.00325 Y25.03717
    X32.47949 Y25.22640
    X33.33055 Y25.74817
    X33.49459 Y25.88823
    X34.18162 Y26.57526
    X34.32167 Y26.73929
    X34.84344 Y27.59036
    X35.03268 Y28.06660
    X35.16235 Y28.44142
    X35.29866 Y29.29249
    Y30.14355
    X35.16235 Y30.99461
    X35.03268 Y31.36944
    X34.84344 Y31.84568
    X34.32167 Y32.69674
    X34.18162 Y32.86077
    X33.49459 Y33.54781
    X33.33055 Y33.68786
    X32.47949 Y34.20963
    X32.00325 Y34.39887
    X31.62843 Y34.52854
    X30.77736 Y34.66485
    X29.92630
    X29.07523 Y34.52854
    X28.70041 Y34.39887
    X28.22417 Y34.20964
    X27.37311 Y33.68786
    X27.20907 Y33.54781
    X26.52204 Y32.86077
    X26.38199 Y32.69674
    X25.86021 Y31.84568
    X25.67098 Y31.36944
    X25.54131 Y30.99461
    X24.09682 Y31.42015
    X22.65234 Y31.84568
    X22.48139 Y30.99461
    X22.38634 Y30.14355
    Y29.29249
    X22.48139 Y28.44142
    X22.65233 Y27.59036
    X22.96124 Y26.73929
    X23.11779 Y26.36845
    X23.35484 Y25.88823
    X23.89594 Y25.03717
    X23.96885 Y24.94545
    X24.61721 Y24.18610
    X24.81991 Y23.98339
    X25.57926 Y23.33504
    X25.67098 Y23.26213
    X26.52204 Y22.72102
    X27.00226 Y22.48397
    X27.37311 Y22.32743
    X28.22417 Y22.01852
    X29.07523 Y21.84758
    X29.92630 Y21.75253
    X30.77736
    X31.62843 Y21.84758
    X32.47949 Y22.01852
    X33.33055 Y22.32743
    X33.70140 Y22.48397
    X34.18162 Y22.72102
    X35.03268 Y23.26213
    X35.12440 Y23.33504
    X35.88374 Y23.98339
    X36.08645 Y24.18610
    X36.73481 Y24.94545
    X36.80772 Y25.03717
    X37.34883 Y25.88823
    X37.58587 Y26.36845
    X37.74242 Y26.73929
    X38.05133 Y27.59036
    X38.22227 Y28.44142
    X38.31731 Y29.29249
    Y30.14355
    X38.22227 Y30.99461
    X38.05132 Y31.84568
    X37.74242 Y32.69674
    X37.58587 Y33.06758
    X37.34882 Y33.54781
    X36.80772 Y34.39887
    X36.73481 Y34.49058
    X36.08646 Y35.24993
    X35.88374 Y35.45265
    X35.12439 Y36.10100
    X35.03268 Y36.17391
    X34.18162 Y36.71501
    X33.70140 Y36.95206
    X33.33055 Y37.10861
    X32.47949 Y37.41751
    X31.62843 Y37.58846
    X30.77736 Y37.68350
    X29.92630
    X29.07523 Y37.58846
    X28.22417 Y37.41751
    X27.37311 Y37.10861
    X27.00225 Y36.95206
    X26.52204 Y36.71502
    X25.67098 Y36.17391
    X25.57926 Y36.10100
    X24.81991 Y35.45264
    X24.61721 Y35.24993
    X23.96885 Y34.49058
    X23.89594 Y34.39887
    X23.35484 Y33.54781
    X23.11779 Y33.06758
    X22.96124 Y32.69674
    X22.65234 Y31.84568
    X21.18293 Y32.15258
    X19.71353 Y32.45948
    X19.57703 Y31.84568
    X19.44609 Y30.99461
    X19.37626 Y30.14355
    Y29.29249
    X19.44609 Y28.44142
    X19.57703 Y27.59036
    X19.71353 Y26.97655
    X19.77269 Y26.73929
    X20.06416 Y25.88823
    X20.42342 Y25.03717
    X20.56460 Y24.73623
    X20.86721 Y24.18610
    X21.41661 Y23.33504
    X22.09319 Y22.48397
    X22.26672 Y22.29394
    X22.92776 Y21.63291
    X23.11779 Y21.45938
    X23.96885 Y20.78280
    X24.81991 Y20.23340
    X25.37004 Y19.93078
    X25.67098 Y19.78961
    X26.52204 Y19.43034
    X27.37311 Y19.13888
    X27.61036 Y19.07972
    X28.22417 Y18.94322
    X29.07523 Y18.81228
    X29.92630 Y18.74245
    X30.77736
    X31.62843 Y18.81228
    X32.47949 Y18.94322
    X33.09329 Y19.07972
    X33.33055 Y19.13888
    X34.18162 Y19.43035
    X35.03268 Y19.78961
    X35.33361 Y19.93078
    X35.88374 Y20.23340
    X36.73481 Y20.78280
    X37.58587 Y21.45938
    X37.77590 Y21.63291
    X38.43694 Y22.29394
    X38.61047 Y22.48397
    X39.28800 Y23.33628
    X39.83645 Y24.18610
    X40.13906 Y24.73623
    X40.28024 Y25.03717
    X40.63950 Y25.88823
    X40.93097 Y26.73929
    X40.99013 Y26.97655
    X41.12662 Y27.59036
    X41.25757 Y28.44142
    X41.32740 Y29.29249
    Y30.14355
    X41.25757 Y30.99461
    X41.12663 Y31.84568
    X40.99013 Y32.45948
    X40.93097 Y32.69674
    X40.63950 Y33.54781
    X40.28024 Y34.39887
    X40.13906 Y34.69979
    X39.83644 Y35.24993
    X39.28704 Y36.10100
    X38.61047 Y36.95206
    X38.43694 Y37.14209
    X37.77591 Y37.80312
    X37.58587 Y37.97666
    X36.73357 Y38.65419
    X35.88374 Y39.20263
    X35.33361 Y39.50525
    X35.03268 Y39.64642
    X34.18162 Y40.00569
    X33.33055 Y40.29716
    X33.09329 Y40.35632
    X32.47949 Y40.49281
    X31.62843 Y40.62376
    X30.77736 Y40.69358
    X29.92630
    X29.07523 Y40.62376
    X28.22417 Y40.49281
    X27.61036 Y40.35632
    X27.37311 Y40.29716
    X26.52204 Y40.00569
    X25.67098 Y39.64643
    X25.37005 Y39.50525
    X24.81991 Y39.20264
    X23.96885 Y38.65324
    X23.11779 Y37.97666
    X22.92776 Y37.80312
    X22.26672 Y37.14209
    X22.09319 Y36.95206
    X21.41566 Y36.09975
    X20.86721 Y35.24993
    X20.56460 Y34.69980
    X20.42342 Y34.39887
    X20.06416 Y33.54781
    X19.77269 Y32.69674
    X19.71353 Y32.45948
    X18.30329 Y33.00364
    X16.89304 Y33.54781
    X16.68084 Y32.69674
    X16.53072 Y31.84568
    X16.42148 Y30.99461
    X16.37099 Y30.14355
    Y29.29249
    X16.42148 Y28.44142
    X16.53071 Y27.59036
    X16.68084 Y26.73929
    X16.89304 Y25.88823
    X17.17558 Y25.03717
    X17.50897 Y24.18610
    X17.90822 Y23.33504
    X18.01140 Y23.13315
    X18.38566 Y22.48397
    X18.86247 Y21.73985
    X19.59329 Y20.78185
    X19.71353 Y20.64098
    X20.36207 Y19.93078
    X20.56460 Y19.72826
    X21.27479 Y19.07972
    X21.41566 Y18.95948
    X22.37366 Y18.22866
    X23.11779 Y17.75185
    X23.76696 Y17.37759
    X23.96885 Y17.27440
    X24.81991 Y16.87515
    X25.71162 Y16.52653
    X26.52204 Y16.25923
    X27.37311 Y16.04703
    X28.22417 Y15.89690
    X29.07523 Y15.78767
    X29.92630 Y15.73717
    X30.77736
    X31.62843 Y15.78767
    X32.47949 Y15.89690
    X33.33055 Y16.04703
    X34.18162 Y16.25923
    X35.03268 Y16.54176
    X35.88374 Y16.87515
    X36.73481 Y17.27440
    X36.93670 Y17.37759
    X37.58587 Y17.75185
    X38.33000 Y18.22866
    X39.28800 Y18.95947
    X39.42887 Y19.07972
    X40.13906 Y19.72826
    X40.34159 Y19.93078
    X40.99013 Y20.64098
    X41.11037 Y20.78185
    X41.84119 Y21.73985
    X42.31800 Y22.48397
    X42.69226 Y23.13316
    X42.79544 Y23.33504
    X43.19469 Y24.18610
    X43.54332 Y25.07780
    X43.81062 Y25.88823
    X44.02281 Y26.73929
    X44.17294 Y27.59036
    X44.28218 Y28.44142
    X44.33267 Y29.29249
    Y30.14355
    X44.28218 Y30.99461
    X44.17294 Y31.84568
    X44.02282 Y32.69674
    X43.81062 Y33.54781
    X43.52808 Y34.39887
    X43.19469 Y35.24993
    X42.79544 Y36.10100
    X42.69226 Y36.30287
    X42.31799 Y36.95206
    X41.84119 Y37.69619
    X41.11037 Y38.65419
    X40.99013 Y38.79506
    X40.34159 Y39.50525
    X40.13906 Y39.70778
    X39.42887 Y40.35632
    X39.28800 Y40.47656
    X38.33000 Y41.20738
    X37.58587 Y41.68418
    X36.93668 Y42.05844
    X36.73481 Y42.16163
    X35.88374 Y42.56088
    X34.99204 Y42.90951
    X34.18162 Y43.17680
    X33.33055 Y43.38900
    X32.47949 Y43.53913
    X31.62843 Y43.64837
    X30.77736 Y43.69886
    X29.92630
    X29.07523 Y43.64837
    X28.22417 Y43.53913
    X27.37311 Y43.38900
    X26.52204 Y43.17681
    X25.67098 Y42.89427
    X24.81991 Y42.56088
    X23.96885 Y42.16163
    X23.76697 Y42.05844
    X23.11779 Y41.68419
    X22.37366 Y41.20738
    X21.41566 Y40.47656
    X21.27479 Y40.35632
    X20.56460 Y39.70778
    X20.36207 Y39.50525
    X19.71353 Y38.79506
    X19.59329 Y38.65419
    X18.86247 Y37.69619
    X18.38566 Y36.95206
    X18.01140 Y36.30288
    X17.90822 Y36.10100
    X17.50897 Y35.24993
    X17.16034 Y34.35823
    X16.89304 Y33.54781
    X15.46228 Y34.00869
    X14.03151 Y34.46957
    X13.72725 Y33.26149
    X13.51590 Y32.06058
    X13.39312 Y30.87617
    X13.35358 Y29.71796
    X13.39134 Y28.55968
    X13.51405 Y27.37514
    X13.72533 Y26.17406
    X14.02956 Y24.96581
    X14.42981 Y23.76073
    X14.92769 Y22.56988
    X15.52310 Y21.40485
    X16.21415 Y20.27736
    X16.99707 Y19.19897
    X17.86628 Y18.18064
    X18.81446 Y17.23247
    X19.83278 Y16.36326
    X20.91117 Y15.58034
    X22.03866 Y14.88929
    X23.20369 Y14.29388
    X24.39454 Y13.79600
    X25.59963 Y13.39575
    X26.80787 Y13.09152
    X28.00895 Y12.88024
    X29.19349 Y12.75753
    X30.35183 Y12.71802
    X31.51017 Y12.75753
    X32.69471 Y12.88024
    X33.89579 Y13.09152
    X35.10403 Y13.39575
    X36.30913 Y13.79600
    X37.49996 Y14.29387
    X38.66499 Y14.88929
    X39.79248 Y15.58034
    X40.87089 Y16.36326
    X41.88920 Y17.23247
    X42.83739 Y18.18064
    X43.70482 Y19.20047
    X44.48766 Y20.27871
    X45.17864 Y21.40602
    X45.77402 Y22.57088
    X46.27189 Y23.76155
    X46.67215 Y24.96646
    X46.97641 Y26.17454
    X47.18776 Y27.37547
    X47.31054 Y28.55986
    X47.35008 Y29.71807
    X47.31052 Y30.87630
    X47.18774 Y32.06070
    X46.97638 Y33.26163
    X46.67211 Y34.46973
    X46.27183 Y35.67464
    X45.77395 Y36.86531
    X45.17856 Y38.03016
    X44.48756 Y39.15748
    X43.70471 Y40.23571
    X42.83561 Y41.25389
    X41.88756 Y42.20193
    X40.86938 Y43.07101
    X39.79115 Y43.85384
    X38.66382 Y44.54483
    X37.49896 Y45.14021
    X36.30830 Y45.63808
    X35.10339 Y46.03834
    X33.89530 Y46.34260
    X32.69439 Y46.55395
    X31.50999 Y46.67672
    X30.35177 Y46.71627
    X29.19356 Y46.67671
    X28.00914 Y46.55392
    X26.80821 Y46.34257
    X25.60013 Y46.03830
    X24.39521 Y45.63802
    X23.20454 Y45.14014
    X22.03968 Y44.54475
    X20.91237 Y43.85375
    X19.83414 Y43.07090
    X18.81597 Y42.20180
    X17.86793 Y41.25375
    X16.99883 Y40.23557
    X16.21600 Y39.15733
    X15.52501 Y38.03001
    X14.92964 Y36.86515
    X14.43178 Y35.67449
    X14.03151 Y34.46957
    G00 Z13.00000
    Z11.34600
    G01 Z8.34600 F350
    X31.80514 Y30.99461 Z8.24877 F350
    X31.62843 Y31.17133 Z8.20470
    X30.77736 Y31.62661 Z8.03451
    X29.92630 Z7.88445
    X29.07523 Y31.17132 Z7.71426
    X28.89853 Y30.99461 Z7.67019
    X28.44323 Y30.14355 Z7.50000
    Y29.29249
    X28.89853 Y28.44142
    X29.07523 Y28.26471
    X29.92630 Y27.80942
    X30.77736
    X31.62843 Y28.26471
    X31.80514 Y28.44142
    X32.26043 Y29.29249
    Y30.14355
    X31.80514 Y30.99461
    X31.62843 Y31.17133
    X30.77736 Y31.62661
    X29.92630
    X29.07523 Y31.17132
    X28.89853 Y30.99461
    X28.44323 Y30.14355
    X26.99227 Y30.56908
    X25.54131 Y30.99461
    X25.40499 Y30.14355
    Y29.29249
    X25.54131 Y28.44142
    X25.67098 Y28.06660
    X25.86021 Y27.59036
    X26.38199 Y26.73929
    X26.52204 Y26.57526
    X27.20907 Y25.88823
    X27.37311 Y25.74817
    X28.22417 Y25.22640
    X28.70041 Y25.03717
    X29.07523 Y24.90750
    X29.92630 Y24.77118
    X30.77736
    X31.62843 Y24.90750
    X32.00325 Y25.03717
    X32.47949 Y25.22640
    X33.33055 Y25.74817
    X33.49459 Y25.88823
    X34.18162 Y26.57526
    X34.32167 Y26.73929
    X34.84344 Y27.59036
    X35.03268 Y28.06660
    X35.16235 Y28.44142
    X35.29866 Y29.29249
    Y30.14355
    X35.16235 Y30.99461
    X35.03268 Y31.36944
    X34.84344 Y31.84568
    X34.32167 Y32.69674
    X34.18162 Y32.86077
    X33.49459 Y33.54781
    X33.33055 Y33.68786
    X32.47949 Y34.20963
    X32.00325 Y34.39887
    X31.62843 Y34.52854
    X30.77736 Y34.66485
    X29.92630
    X29.07523 Y34.52854
    X28.70041 Y34.39887
    X28.22417 Y34.20964
    X27.37311 Y33.68786
    X27.20907 Y33.54781
    X26.52204 Y32.86077
    X26.38199 Y32.69674
    X25.86021 Y31.84568
    X25.67098 Y31.36944
    X25.54131 Y30.99461
    X24.09682 Y31.42015
    X22.65234 Y31.84568
    X22.48139 Y30.99461
    X22.38634 Y30.14355
    Y29.29249
    X22.48139 Y28.44142
    X22.65233 Y27.59036
    X22.96124 Y26.73929
    X23.11779 Y26.36845
    X23.35484 Y25.88823
    X23.89594 Y25.03717
    X23.96885 Y24.94545
    X24.61721 Y24.18610
    X24.81991 Y23.98339
    X25.57926 Y23.33504
    X25.67098 Y23.26213
    X26.52204 Y22.72102
    X27.00226 Y22.48397
    X27.37311 Y22.32743
    X28.22417 Y22.01852
    X29.07523 Y21.84758
    X29.92630 Y21.75253
    X30.77736
    X31.62843 Y21.84758
    X32.47949 Y22.01852
    X33.33055 Y22.32743
    X33.70140 Y22.48397
    X34.18162 Y22.72102
    X35.03268 Y23.26213
    X35.12440 Y23.33504
    X35.88374 Y23.98339
    X36.08645 Y24.18610
    X36.73481 Y24.94545
    X36.80772 Y25.03717
    X37.34883 Y25.88823
    X37.58587 Y26.36845
    X37.74242 Y26.73929
    X38.05133 Y27.59036
    X38.22227 Y28.44142
    X38.31731 Y29.29249
    Y30.14355
    X38.22227 Y30.99461
    X38.05132 Y31.84568
    X37.74242 Y32.69674
    X37.58587 Y33.06758
    X37.34882 Y33.54781
    X36.80772 Y34.39887
    X36.73481 Y34.49058
    X36.08646 Y35.24993
    X35.88374 Y35.45265
    X35.12439 Y36.10100
    X35.03268 Y36.17391
    X34.18162 Y36.71501
    X33.70140 Y36.95206
    X33.33055 Y37.10861
    X32.47949 Y37.41751
    X31.62843 Y37.58846
    X30.77736 Y37.68350
    X29.92630
    X29.07523 Y37.58846
    X28.22417 Y37.41751
    X27.37311 Y37.10861
    X27.00225 Y36.95206
    X26.52204 Y36.71502
    X25.67098 Y36.17391
    X25.57926 Y36.10100
    X24.81991 Y35.45264
    X24.61721 Y35.24993
    X23.96885 Y34.49058
    X23.89594 Y34.39887
    X23.35484 Y33.54781
    X23.11779 Y33.06758
    X22.96124 Y32.69674
    X22.65234 Y31.84568
    X21.18293 Y32.15258
    X19.71353 Y32.45948
    X19.57703 Y31.84568
    X19.44609 Y30.99461
    X19.37626 Y30.14355
    Y29.29249
    X19.44609 Y28.44142
    X19.57703 Y27.59036
    X19.71353 Y26.97655
    X19.77269 Y26.73929
    X20.06416 Y25.88823
    X20.42342 Y25.03717
    X20.56460 Y24.73623
    X20.86721 Y24.18610
    X21.41661 Y23.33504
    X22.09319 Y22.48397
    X22.26672 Y22.29394
    X22.92776 Y21.63291
    X23.11779 Y21.45938
    X23.96885 Y20.78280
    X24.81991 Y20.23340
    X25.37004 Y19.93078
    X25.67098 Y19.78961
    X26.52204 Y19.43034
    X27.37311 Y19.13888
    X27.61036 Y19.07972
    X28.22417 Y18.94322
    X29.07523 Y18.81228
    X29.92630 Y18.74245
    X30.77736
    X31.62843 Y18.81228
    X32.47949 Y18.94322
    X33.09329 Y19.07972
    X33.33055 Y19.13888
    X34.18162 Y19.43035
    X35.03268 Y19.78961
    X35.33361 Y19.93078
    X35.88374 Y20.23340
    X36.73481 Y20.78280
    X37.58587 Y21.45938
    X37.77590 Y21.63291
    X38.43694 Y22.29394
    X38.61047 Y22.48397
    X39.28800 Y23.33628
    X39.83645 Y24.18610
    X40.13906 Y24.73623
    X40.28024 Y25.03717
    X40.63950 Y25.88823
    X40.93097 Y26.73929
    X40.99013 Y26.97655
    X41.12662 Y27.59036
    X41.25757 Y28.44142
    X41.32740 Y29.29249
    Y30.14355
    X41.25757 Y30.99461
    X41.12663 Y31.84568
    X40.99013 Y32.45948
    X40.93097 Y32.69674
    X40.63950 Y33.54781
    X40.28024 Y34.39887
    X40.13906 Y34.69979
    X39.83644 Y35.24993
    X39.28704 Y36.10100
    X38.61047 Y36.95206
    X38.43694 Y37.14209
    X37.77591 Y37.80312
    X37.58587 Y37.97666
    X36.73357 Y38.65419
    X35.88374 Y39.20263
    X35.33361 Y39.50525
    X35.03268 Y39.64642
    X34.18162 Y40.00569
    X33.33055 Y40.29716
    X33.09329 Y40.35632
    X32.47949 Y40.49281
    X31.62843 Y40.62376
    X30.77736 Y40.69358
    X29.92630
    X29.07523 Y40.62376
    X28.22417 Y40.49281
    X27.61036 Y40.35632
    X27.37311 Y40.29716
    X26.52204 Y40.00569
    X25.67098 Y39.64643
    X25.37005 Y39.50525
    X24.81991 Y39.20264
    X23.96885 Y38.65324
    X23.11779 Y37.97666
    X22.92776 Y37.80312
    X22.26672 Y37.14209
    X22.09319 Y36.95206
    X21.41566 Y36.09975
    X20.86721 Y35.24993
    X20.56460 Y34.69980
    X20.42342 Y34.39887
    X20.06416 Y33.54781
    X19.77269 Y32.69674
    X19.71353 Y32.45948
    X18.30329 Y33.00364
    X16.89304 Y33.54781
    X16.68084 Y32.69674
    X16.53072 Y31.84568
    X16.42148 Y30.99461
    X16.37099 Y30.14355
    Y29.29249
    X16.42148 Y28.44142
    X16.53071 Y27.59036
    X16.68084 Y26.73929
    X16.89304 Y25.88823
    X17.17558 Y25.03717
    X17.50897 Y24.18610
    X17.90822 Y23.33504
    X18.01140 Y23.13315
    X18.38566 Y22.48397
    X18.86247 Y21.73985
    X19.59329 Y20.78185
    X19.71353 Y20.64098
    X20.36207 Y19.93078
    X20.56460 Y19.72826
    X21.27479 Y19.07972
    X21.41566 Y18.95948
    X22.37366 Y18.22866
    X23.11779 Y17.75185
    X23.76696 Y17.37759
    X23.96885 Y17.27440
    X24.81991 Y16.87515
    X25.71162 Y16.52653
    X26.52204 Y16.25923
    X27.37311 Y16.04703
    X28.22417 Y15.89690
    X29.07523 Y15.78767
    X29.92630 Y15.73717
    X30.77736
    X31.62843 Y15.78767
    X32.47949 Y15.89690
    X33.33055 Y16.04703
    X34.18162 Y16.25923
    X35.03268 Y16.54176
    X35.88374 Y16.87515
    X36.73481 Y17.27440
    X36.93670 Y17.37759
    X37.58587 Y17.75185
    X38.33000 Y18.22866
    X39.28800 Y18.95947
    X39.42887 Y19.07972
    X40.13906 Y19.72826
    X40.34159 Y19.93078
    X40.99013 Y20.64098
    X41.11037 Y20.78185
    X41.84119 Y21.73985
    X42.31800 Y22.48397
    X42.69226 Y23.13316
    X42.79544 Y23.33504
    X43.19469 Y24.18610
    X43.54332 Y25.07780
    X43.81062 Y25.88823
    X44.02281 Y26.73929
    X44.17294 Y27.59036
    X44.28218 Y28.44142
    X44.33267 Y29.29249
    Y30.14355
    X44.28218 Y30.99461
    X44.17294 Y31.84568
    X44.02282 Y32.69674
    X43.81062 Y33.54781
    X43.52808 Y34.39887
    X43.19469 Y35.24993
    X42.79544 Y36.10100
    X42.69226 Y36.30287
    X42.31799 Y36.95206
    X41.84119 Y37.69619
    X41.11037 Y38.65419
    X40.99013 Y38.79506
    X40.34159 Y39.50525
    X40.13906 Y39.70778
    X39.42887 Y40.35632
    X39.28800 Y40.47656
    X38.33000 Y41.20738
    X37.58587 Y41.68418
    X36.93668 Y42.05844
    X36.73481 Y42.16163
    X35.88374 Y42.56088
    X34.99204 Y42.90951
    X34.18162 Y43.17680
    X33.33055 Y43.38900
    X32.47949 Y43.53913
    X31.62843 Y43.64837
    X30.77736 Y43.69886
    X29.92630
    X29.07523 Y43.64837
    X28.22417 Y43.53913
    X27.37311 Y43.38900
    X26.52204 Y43.17681
    X25.67098 Y42.89427
    X24.81991 Y42.56088
    X23.96885 Y42.16163
    X23.76697 Y42.05844
    X23.11779 Y41.68419
    X22.37366 Y41.20738
    X21.41566 Y40.47656
    X21.27479 Y40.35632
    X20.56460 Y39.70778
    X20.36207 Y39.50525
    X19.71353 Y38.79506
    X19.59329 Y38.65419
    X18.86247 Y37.69619
    X18.38566 Y36.95206
    X18.01140 Y36.30288
    X17.90822 Y36.10100
    X17.50897 Y35.24993
    X17.16034 Y34.35823
    X16.89304 Y33.54781
    X15.46228 Y34.00869
    X14.03151 Y34.46957
    X13.72725 Y33.26149
    X13.51590 Y32.06058
    X13.39312 Y30.87617
    X13.35358 Y29.71796
    X13.39134 Y28.55968
    X13.51405 Y27.37514
    X13.72533 Y26.17406
    X14.02956 Y24.96581
    X14.42981 Y23.76073
    X14.92769 Y22.56988
    X15.52310 Y21.40485
    X16.21415 Y20.27736
    X16.99707 Y19.19897
    X17.86628 Y18.18064
    X18.81446 Y17.23247
    X19.83278 Y16.36326
    X20.91117 Y15.58034
    X22.03866 Y14.88929
    X23.20369 Y14.29388
    X24.39454 Y13.79600
    X25.59963 Y13.39575
    X26.80787 Y13.09152
    X28.00895 Y12.88024
    X29.19349 Y12.75753
    X30.35183 Y12.71802
    X31.51017 Y12.75753
    X32.69471 Y12.88024
    X33.89579 Y13.09152
    X35.10403 Y13.39575
    X36.30913 Y13.79600
    X37.49996 Y14.29387
    X38.66499 Y14.88929
    X39.79248 Y15.58034
    X40.87089 Y16.36326
    X41.88920 Y17.23247
    X42.83739 Y18.18064
    X43.70482 Y19.20047
    X44.48766 Y20.27871
    X45.17864 Y21.40602
    X45.77402 Y22.57088
    X46.27189 Y23.76155
    X46.67215 Y24.96646
    X46.97641 Y26.17454
    X47.18776 Y27.37547
    X47.31054 Y28.55986
    X47.35008 Y29.71807
    X47.31052 Y30.87630
    X47.18774 Y32.06070
    X46.97638 Y33.26163
    X46.67211 Y34.46973
    X46.27183 Y35.67464
    X45.77395 Y36.86531
    X45.17856 Y38.03016
    X44.48756 Y39.15748
    X43.70471 Y40.23571
    X42.83561 Y41.25389
    X41.88756 Y42.20193
    X40.86938 Y43.07101
    X39.79115 Y43.85384
    X38.66382 Y44.54483
    X37.49896 Y45.14021
    X36.30830 Y45.63808
    X35.10339 Y46.03834
    X33.89530 Y46.34260
    X32.69439 Y46.55395
    X31.50999 Y46.67672
    X30.35177 Y46.71627
    X29.19356 Y46.67671
    X28.00914 Y46.55392
    X26.80821 Y46.34257
    X25.60013 Y46.03830
    X24.39521 Y45.63802
    X23.20454 Y45.14014
    X22.03968 Y44.54475
    X20.91237 Y43.85375
    X19.83414 Y43.07090
    X18.81597 Y42.20180
    X17.86793 Y41.25375
    X16.99883 Y40.23557
    X16.21600 Y39.15733
    X15.52501 Y38.03001
    X14.92964 Y36.86515
    X14.43178 Y35.67449
    X14.03151 Y34.46957
    G00 Z13.00000
    Z10.51267
    G01 Z7.51267 F350
    X31.80514 Y30.99461 Z7.41543 F350
    X31.62843 Y31.17133 Z7.37137
    X30.77736 Y31.62661 Z7.20118
    X29.92630 Z7.05111
    X29.07523 Y31.17132 Z6.88092
    X28.89853 Y30.99461 Z6.83686
    X28.44323 Y30.14355 Z6.66667
    Y29.29249
    X28.89853 Y28.44142
    X29.07523 Y28.26471
    X29.92630 Y27.80942
    X30.77736
    X31.62843 Y28.26471
    X31.80514 Y28.44142
    X32.26043 Y29.29249
    Y30.14355
    X31.80514 Y30.99461
    X31.62843 Y31.17133
    X30.77736 Y31.62661
    X29.92630
    X29.07523 Y31.17132
    X28.89853 Y30.99461
    X28.44323 Y30.14355
    X26.99227 Y30.56908
    X25.54131 Y30.99461
    X25.40499 Y30.14355
    Y29.29249
    X25.54131 Y28.44142
    X25.67098 Y28.06660
    X25.86021 Y27.59036
    X26.38199 Y26.73929
    X26.52204 Y26.57526
    X27.20907 Y25.88823
    X27.37311 Y25.74817
    X28.22417 Y25.22640
    X28.70041 Y25.03717
    X29.07523 Y24.90750
    X29.92630 Y24.77118
    X30.77736
    X31.62843 Y24.90750
    X32.00325 Y25.03717
    X32.47949 Y25.22640
    X33.33055 Y25.74817
    X33.49459 Y25.88823
    X34.18162 Y26.57526
    X34.32167 Y26.73929
    X34.84344 Y27.59036
    X35.03268 Y28.06660
    X35.16235 Y28.44142
    X35.29866 Y29.29249
    Y30.14355
    X35.16235 Y30.99461
    X35.03268 Y31.36944
    X34.84344 Y31.84568
    X34.32167 Y32.69674
    X34.18162 Y32.86077
    X33.49459 Y33.54781
    X33.33055 Y33.68786
    X32.47949 Y34.20963
    X32.00325 Y34.39887
    X31.62843 Y34.52854
    X30.77736 Y34.66485
    X29.92630
    X29.07523 Y34.52854
    X28.70041 Y34.39887
    X28.22417 Y34.20964
    X27.37311 Y33.68786
    X27.20907 Y33.54781
    X26.52204 Y32.86077
    X26.38199 Y32.69674
    X25.86021 Y31.84568
    X25.67098 Y31.36944
    X25.54131 Y30.99461
    X24.09682 Y31.42015
    X22.65234 Y31.84568
    X22.48139 Y30.99461
    X22.38634 Y30.14355
    Y29.29249
    X22.48139 Y28.44142
    X22.65233 Y27.59036
    X22.96124 Y26.73929
    X23.11779 Y26.36845
    X23.35484 Y25.88823
    X23.89594 Y25.03717
    X23.96885 Y24.94545
    X24.61721 Y24.18610
    X24.81991 Y23.98339
    X25.57926 Y23.33504
    X25.67098 Y23.26213
    X26.52204 Y22.72102
    X27.00226 Y22.48397
    X27.37311 Y22.32743
    X28.22417 Y22.01852
    X29.07523 Y21.84758
    X29.92630 Y21.75253
    X30.77736
    X31.62843 Y21.84758
    X32.47949 Y22.01852
    X33.33055 Y22.32743
    X33.70140 Y22.48397
    X34.18162 Y22.72102
    X35.03268 Y23.26213
    X35.12440 Y23.33504
    X35.88374 Y23.98339
    X36.08645 Y24.18610
    X36.73481 Y24.94545
    X36.80772 Y25.03717
    X37.34883 Y25.88823
    X37.58587 Y26.36845
    X37.74242 Y26.73929
    X38.05133 Y27.59036
    X38.22227 Y28.44142
    X38.31731 Y29.29249
    Y30.14355
    X38.22227 Y30.99461
    X38.05132 Y31.84568
    X37.74242 Y32.69674
    X37.58587 Y33.06758
    X37.34882 Y33.54781
    X36.80772 Y34.39887
    X36.73481 Y34.49058
    X36.08646 Y35.24993
    X35.88374 Y35.45265
    X35.12439 Y36.10100
    X35.03268 Y36.17391
    X34.18162 Y36.71501
    X33.70140 Y36.95206
    X33.33055 Y37.10861
    X32.47949 Y37.41751
    X31.62843 Y37.58846
    X30.77736 Y37.68350
    X29.92630
    X29.07523 Y37.58846
    X28.22417 Y37.41751
    X27.37311 Y37.10861
    X27.00225 Y36.95206
    X26.52204 Y36.71502
    X25.67098 Y36.17391
    X25.57926 Y36.10100
    X24.81991 Y35.45264
    X24.61721 Y35.24993
    X23.96885 Y34.49058
    X23.89594 Y34.39887
    X23.35484 Y33.54781
    X23.11779 Y33.06758
    X22.96124 Y32.69674
    X22.65234 Y31.84568
    X21.18293 Y32.15258
    X19.71353 Y32.45948
    X19.57703 Y31.84568
    X19.44609 Y30.99461
    X19.37626 Y30.14355
    Y29.29249
    X19.44609 Y28.44142
    X19.57703 Y27.59036
    X19.71353 Y26.97655
    X19.77269 Y26.73929
    X20.06416 Y25.88823
    X20.42342 Y25.03717
    X20.56460 Y24.73623
    X20.86721 Y24.18610
    X21.41661 Y23.33504
    X22.09319 Y22.48397
    X22.26672 Y22.29394
    X22.92776 Y21.63291
    X23.11779 Y21.45938
    X23.96885 Y20.78280
    X24.81991 Y20.23340
    X25.37004 Y19.93078
    X25.67098 Y19.78961
    X26.52204 Y19.43034
    X27.37311 Y19.13888
    X27.61036 Y19.07972
    X28.22417 Y18.94322
    X29.07523 Y18.81228
    X29.92630 Y18.74245
    X30.77736
    X31.62843 Y18.81228
    X32.47949 Y18.94322
    X33.09329 Y19.07972
    X33.33055 Y19.13888
    X34.18162 Y19.43035
    X35.03268 Y19.78961
    X35.33361 Y19.93078
    X35.88374 Y20.23340
    X36.73481 Y20.78280
    X37.58587 Y21.45938
    X37.77590 Y21.63291
    X38.43694 Y22.29394
    X38.61047 Y22.48397
    X39.28800 Y23.33628
    X39.83645 Y24.18610
    X40.13906 Y24.73623
    X40.28024 Y25.03717
    X40.63950 Y25.88823
    X40.93097 Y26.73929
    X40.99013 Y26.97655
    X41.12662 Y27.59036
    X41.25757 Y28.44142
    X41.32740 Y29.29249
    Y30.14355
    X41.25757 Y30.99461
    X41.12663 Y31.84568
    X40.99013 Y32.45948
    X40.93097 Y32.69674
    X40.63950 Y33.54781
    X40.28024 Y34.39887
    X40.13906 Y34.69979
    X39.83644 Y35.24993
    X39.28704 Y36.10100
    X38.61047 Y36.95206
    X38.43694 Y37.14209
    X37.77591 Y37.80312
    X37.58587 Y37.97666
    X36.73357 Y38.65419
    X35.88374 Y39.20263
    X35.33361 Y39.50525
    X35.03268 Y39.64642
    X34.18162 Y40.00569
    X33.33055 Y40.29716
    X33.09329 Y40.35632
    X32.47949 Y40.49281
    X31.62843 Y40.62376
    X30.77736 Y40.69358
    X29.92630
    X29.07523 Y40.62376
    X28.22417 Y40.49281
    X27.61036 Y40.35632
    X27.37311 Y40.29716
    X26.52204 Y40.00569
    X25.67098 Y39.64643
    X25.37005 Y39.50525
    X24.81991 Y39.20264
    X23.96885 Y38.65324
    X23.11779 Y37.97666
    X22.92776 Y37.80312
    X22.26672 Y37.14209
    X22.09319 Y36.95206
    X21.41566 Y36.09975
    X20.86721 Y35.24993
    X20.56460 Y34.69980
    X20.42342 Y34.39887
    X20.06416 Y33.54781
    X19.77269 Y32.69674
    X19.71353 Y32.45948
    X18.30329 Y33.00364
    X16.89304 Y33.54781
    X16.68084 Y32.69674
    X16.53072 Y31.84568
    X16.42148 Y30.99461
    X16.37099 Y30.14355
    Y29.29249
    X16.42148 Y28.44142
    X16.53071 Y27.59036
    X16.68084 Y26.73929
    X16.89304 Y25.88823
    X17.17558 Y25.03717
    X17.50897 Y24.18610
    X17.90822 Y23.33504
    X18.01140 Y23.13315
    X18.38566 Y22.48397
    X18.86247 Y21.73985
    X19.59329 Y20.78185
    X19.71353 Y20.64098
    X20.36207 Y19.93078
    X20.56460 Y19.72826
    X21.27479 Y19.07972
    X21.41566 Y18.95948
    X22.37366 Y18.22866
    X23.11779 Y17.75185
    X23.76696 Y17.37759
    X23.96885 Y17.27440
    X24.81991 Y16.87515
    X25.71162 Y16.52653
    X26.52204 Y16.25923
    X27.37311 Y16.04703
    X28.22417 Y15.89690
    X29.07523 Y15.78767
    X29.92630 Y15.73717
    X30.77736
    X31.62843 Y15.78767
    X32.47949 Y15.89690
    X33.33055 Y16.04703
    X34.18162 Y16.25923
    X35.03268 Y16.54176
    X35.88374 Y16.87515
    X36.73481 Y17.27440
    X36.93670 Y17.37759
    X37.58587 Y17.75185
    X38.33000 Y18.22866
    X39.28800 Y18.95947
    X39.42887 Y19.07972
    X40.13906 Y19.72826
    X40.34159 Y19.93078
    X40.99013 Y20.64098
    X41.11037 Y20.78185
    X41.84119 Y21.73985
    X42.31800 Y22.48397
    X42.69226 Y23.13316
    X42.79544 Y23.33504
    X43.19469 Y24.18610
    X43.54332 Y25.07780
    X43.81062 Y25.88823
    X44.02281 Y26.73929
    X44.17294 Y27.59036
    X44.28218 Y28.44142
    X44.33267 Y29.29249
    Y30.14355
    X44.28218 Y30.99461
    X44.17294 Y31.84568
    X44.02282 Y32.69674
    X43.81062 Y33.54781
    X43.52808 Y34.39887
    X43.19469 Y35.24993
    X42.79544 Y36.10100
    X42.69226 Y36.30287
    X42.31799 Y36.95206
    X41.84119 Y37.69619
    X41.11037 Y38.65419
    X40.99013 Y38.79506
    X40.34159 Y39.50525
    X40.13906 Y39.70778
    X39.42887 Y40.35632
    X39.28800 Y40.47656
    X38.33000 Y41.20738
    X37.58587 Y41.68418
    X36.93668 Y42.05844
    X36.73481 Y42.16163
    X35.88374 Y42.56088
    X34.99204 Y42.90951
    X34.18162 Y43.17680
    X33.33055 Y43.38900
    X32.47949 Y43.53913
    X31.62843 Y43.64837
    X30.77736 Y43.69886
    X29.92630
    X29.07523 Y43.64837
    X28.22417 Y43.53913
    X27.37311 Y43.38900
    X26.52204 Y43.17681
    X25.67098 Y42.89427
    X24.81991 Y42.56088
    X23.96885 Y42.16163
    X23.76697 Y42.05844
    X23.11779 Y41.68419
    X22.37366 Y41.20738
    X21.41566 Y40.47656
    X21.27479 Y40.35632
    X20.56460 Y39.70778
    X20.36207 Y39.50525
    X19.71353 Y38.79506
    X19.59329 Y38.65419
    X18.86247 Y37.69619
    X18.38566 Y36.95206
    X18.01140 Y36.30288
    X17.90822 Y36.10100
    X17.50897 Y35.24993
    X17.16034 Y34.35823
    X16.89304 Y33.54781
    X15.46228 Y34.00869
    X14.03151 Y34.46957
    X13.72725 Y33.26149
    X13.51590 Y32.06058
    X13.39312 Y30.87617
    X13.35358 Y29.71796
    X13.39134 Y28.55968
    X13.51405 Y27.37514
    X13.72533 Y26.17406
    X14.02956 Y24.96581
    X14.42981 Y23.76073
    X14.92769 Y22.56988
    X15.52310 Y21.40485
    X16.21415 Y20.27736
    X16.99707 Y19.19897
    X17.86628 Y18.18064
    X18.81446 Y17.23247
    X19.83278 Y16.36326
    X20.91117 Y15.58034
    X22.03866 Y14.88929
    X23.20369 Y14.29388
    X24.39454 Y13.79600
    X25.59963 Y13.39575
    X26.80787 Y13.09152
    X28.00895 Y12.88024
    X29.19349 Y12.75753
    X30.35183 Y12.71802
    X31.51017 Y12.75753
    X32.69471 Y12.88024
    X33.89579 Y13.09152
    X35.10403 Y13.39575
    X36.30913 Y13.79600
    X37.49996 Y14.29387
    X38.66499 Y14.88929
    X39.79248 Y15.58034
    X40.87089 Y16.36326
    X41.88920 Y17.23247
    X42.83739 Y18.18064
    X43.70482 Y19.20047
    X44.48766 Y20.27871
    X45.17864 Y21.40602
    X45.77402 Y22.57088
    X46.27189 Y23.76155
    X46.67215 Y24.96646
    X46.97641 Y26.17454
    X47.18776 Y27.37547
    X47.31054 Y28.55986
    X47.35008 Y29.71807
    X47.31052 Y30.87630
    X47.18774 Y32.06070
    X46.97638 Y33.26163
    X46.67211 Y34.46973
    X46.27183 Y35.67464
    X45.77395 Y36.86531
    X45.17856 Y38.03016
    X44.48756 Y39.15748
    X43.70471 Y40.23571
    X42.83561 Y41.25389
    X41.88756 Y42.20193
    X40.86938 Y43.07101
    X39.79115 Y43.85384
    X38.66382 Y44.54483
    X37.49896 Y45.14021
    X36.30830 Y45.63808
    X35.10339 Y46.03834
    X33.89530 Y46.34260
    X32.69439 Y46.55395
    X31.50999 Y46.67672
    X30.35177 Y46.71627
    X29.19356 Y46.67671
    X28.00914 Y46.55392
    X26.80821 Y46.34257
    X25.60013 Y46.03830
    X24.39521 Y45.63802
    X23.20454 Y45.14014
    X22.03968 Y44.54475
    X20.91237 Y43.85375
    X19.83414 Y43.07090
    X18.81597 Y42.20180
    X17.86793 Y41.25375
    X16.99883 Y40.23557
    X16.21600 Y39.15733
    X15.52501 Y38.03001
    X14.92964 Y36.86515
    X14.43178 Y35.67449
    X14.03151 Y34.46957
    G00 Z13.00000
    Z9.67933
    G01 Z6.67933 F350
    X31.80514 Y30.99461 Z6.58210 F350
    X31.62843 Y31.17133 Z6.53803
    X30.77736 Y31.62661 Z6.36784
    X29.92630 Z6.21778
    X29.07523 Y31.17132 Z6.04759
    X28.89853 Y30.99461 Z6.00352
    X28.44323 Y30.14355 Z5.83333
    Y29.29249
    X28.89853 Y28.44142
    X29.07523 Y28.26471
    X29.92630 Y27.80942
    X30.77736
    X31.62843 Y28.26471
    X31.80514 Y28.44142
    X32.26043 Y29.29249
    Y30.14355
    X31.80514 Y30.99461
    X31.62843 Y31.17133
    X30.77736 Y31.62661
    X29.92630
    X29.07523 Y31.17132
    X28.89853 Y30.99461
    X28.44323 Y30.14355
    X26.99227 Y30.56908
    X25.54131 Y30.99461
    X25.40499 Y30.14355
    Y29.29249
    X25.54131 Y28.44142
    X25.67098 Y28.06660
    X25.86021 Y27.59036
    X26.38199 Y26.73929
    X26.52204 Y26.57526
    X27.20907 Y25.88823
    X27.37311 Y25.74817
    X28.22417 Y25.22640
    X28.70041 Y25.03717
    X29.07523 Y24.90750
    X29.92630 Y24.77118
    X30.77736
    X31.62843 Y24.90750
    X32.00325 Y25.03717
    X32.47949 Y25.22640
    X33.33055 Y25.74817
    X33.49459 Y25.88823
    X34.18162 Y26.57526
    X34.32167 Y26.73929
    X34.84344 Y27.59036
    X35.03268 Y28.06660
    X35.16235 Y28.44142
    X35.29866 Y29.29249
    Y30.14355
    X35.16235 Y30.99461
    X35.03268 Y31.36944
    X34.84344 Y31.84568
    X34.32167 Y32.69674
    X34.18162 Y32.86077
    X33.49459 Y33.54781
    X33.33055 Y33.68786
    X32.47949 Y34.20963
    X32.00325 Y34.39887
    X31.62843 Y34.52854
    X30.77736 Y34.66485
    X29.92630
    X29.07523 Y34.52854
    X28.70041 Y34.39887
    X28.22417 Y34.20964
    X27.37311 Y33.68786
    X27.20907 Y33.54781
    X26.52204 Y32.86077
    X26.38199 Y32.69674
    X25.86021 Y31.84568
    X25.67098 Y31.36944
    X25.54131 Y30.99461
    X24.09682 Y31.42015
    X22.65234 Y31.84568
    X22.48139 Y30.99461
    X22.38634 Y30.14355
    Y29.29249
    X22.48139 Y28.44142
    X22.65233 Y27.59036
    X22.96124 Y26.73929
    X23.11779 Y26.36845
    X23.35484 Y25.88823
    X23.89594 Y25.03717
    X23.96885 Y24.94545
    X24.61721 Y24.18610
    X24.81991 Y23.98339
    X25.57926 Y23.33504
    X25.67098 Y23.26213
    X26.52204 Y22.72102
    X27.00226 Y22.48397
    X27.37311 Y22.32743
    X28.22417 Y22.01852
    X29.07523 Y21.84758
    X29.92630 Y21.75253
    X30.77736
    X31.62843 Y21.84758
    X32.47949 Y22.01852
    X33.33055 Y22.32743
    X33.70140 Y22.48397
    X34.18162 Y22.72102
    X35.03268 Y23.26213
    X35.12440 Y23.33504
    X35.88374 Y23.98339
    X36.08645 Y24.18610
    X36.73481 Y24.94545
    X36.80772 Y25.03717
    X37.34883 Y25.88823
    X37.58587 Y26.36845
    X37.74242 Y26.73929
    X38.05133 Y27.59036
    X38.22227 Y28.44142
    X38.31731 Y29.29249
    Y30.14355
    X38.22227 Y30.99461
    X38.05132 Y31.84568
    X37.74242 Y32.69674
    X37.58587 Y33.06758
    X37.34882 Y33.54781
    X36.80772 Y34.39887
    X36.73481 Y34.49058
    X36.08646 Y35.24993
    X35.88374 Y35.45265
    X35.12439 Y36.10100
    X35.03268 Y36.17391
    X34.18162 Y36.71501
    X33.70140 Y36.95206
    X33.33055 Y37.10861
    X32.47949 Y37.41751
    X31.62843 Y37.58846
    X30.77736 Y37.68350
    X29.92630
    X29.07523 Y37.58846
    X28.22417 Y37.41751
    X27.37311 Y37.10861
    X27.00225 Y36.95206
    X26.52204 Y36.71502
    X25.67098 Y36.17391
    X25.57926 Y36.10100
    X24.81991 Y35.45264
    X24.61721 Y35.24993
    X23.96885 Y34.49058
    X23.89594 Y34.39887
    X23.35484 Y33.54781
    X23.11779 Y33.06758
    X22.96124 Y32.69674
    X22.65234 Y31.84568
    X21.18293 Y32.15258
    X19.71353 Y32.45948
    X19.57703 Y31.84568
    X19.44609 Y30.99461
    X19.37626 Y30.14355
    Y29.29249
    X19.44609 Y28.44142
    X19.57703 Y27.59036
    X19.71353 Y26.97655
    X19.77269 Y26.73929
    X20.06416 Y25.88823
    X20.42342 Y25.03717
    X20.56460 Y24.73623
    X20.86721 Y24.18610
    X21.41661 Y23.33504
    X22.09319 Y22.48397
    X22.26672 Y22.29394
    X22.92776 Y21.63291
    X23.11779 Y21.45938
    X23.96885 Y20.78280
    X24.81991 Y20.23340
    X25.37004 Y19.93078
    X25.67098 Y19.78961
    X26.52204 Y19.43034
    X27.37311 Y19.13888
    X27.61036 Y19.07972
    X28.22417 Y18.94322
    X29.07523 Y18.81228
    X29.92630 Y18.74245
    X30.77736
    X31.62843 Y18.81228
    X32.47949 Y18.94322
    X33.09329 Y19.07972
    X33.33055 Y19.13888
    X34.18162 Y19.43035
    X35.03268 Y19.78961
    X35.33361 Y19.93078
    X35.88374 Y20.23340
    X36.73481 Y20.78280
    X37.58587 Y21.45938
    X37.77590 Y21.63291
    X38.43694 Y22.29394
    X38.61047 Y22.48397
    X39.28800 Y23.33628
    X39.83645 Y24.18610
    X40.13906 Y24.73623
    X40.28024 Y25.03717
    X40.63950 Y25.88823
    X40.93097 Y26.73929
    X40.99013 Y26.97655
    X41.12662 Y27.59036
    X41.25757 Y28.44142
    X41.32740 Y29.29249
    Y30.14355
    X41.25757 Y30.99461
    X41.12663 Y31.84568
    X40.99013 Y32.45948
    X40.93097 Y32.69674
    X40.63950 Y33.54781
    X40.28024 Y34.39887
    X40.13906 Y34.69979
    X39.83644 Y35.24993
    X39.28704 Y36.10100
    X38.61047 Y36.95206
    X38.43694 Y37.14209
    X37.77591 Y37.80312
    X37.58587 Y37.97666
    X36.73357 Y38.65419
    X35.88374 Y39.20263
    X35.33361 Y39.50525
    X35.03268 Y39.64642
    X34.18162 Y40.00569
    X33.33055 Y40.29716
    X33.09329 Y40.35632
    X32.47949 Y40.49281
    X31.62843 Y40.62376
    X30.77736 Y40.69358
    X29.92630
    X29.07523 Y40.62376
    X28.22417 Y40.49281
    X27.61036 Y40.35632
    X27.37311 Y40.29716
    X26.52204 Y40.00569
    X25.67098 Y39.64643
    X25.37005 Y39.50525
    X24.81991 Y39.20264
    X23.96885 Y38.65324
    X23.11779 Y37.97666
    X22.92776 Y37.80312
    X22.26672 Y37.14209
    X22.09319 Y36.95206
    X21.41566 Y36.09975
    X20.86721 Y35.24993
    X20.56460 Y34.69980
    X20.42342 Y34.39887
    X20.06416 Y33.54781
    X19.77269 Y32.69674
    X19.71353 Y32.45948
    X18.30329 Y33.00364
    X16.89304 Y33.54781
    X16.68084 Y32.69674
    X16.53072 Y31.84568
    X16.42148 Y30.99461
    X16.37099 Y30.14355
    Y29.29249
    X16.42148 Y28.44142
    X16.53071 Y27.59036
    X16.68084 Y26.73929
    X16.89304 Y25.88823
    X17.17558 Y25.03717
    X17.50897 Y24.18610
    X17.90822 Y23.33504
    X18.01140 Y23.13315
    X18.38566 Y22.48397
    X18.86247 Y21.73985
    X19.59329 Y20.78185
    X19.71353 Y20.64098
    X20.36207 Y19.93078
    X20.56460 Y19.72826
    X21.27479 Y19.07972
    X21.41566 Y18.95948
    X22.37366 Y18.22866
    X23.11779 Y17.75185
    X23.76696 Y17.37759
    X23.96885 Y17.27440
    X24.81991 Y16.87515
    X25.71162 Y16.52653
    X26.52204 Y16.25923
    X27.37311 Y16.04703
    X28.22417 Y15.89690
    X29.07523 Y15.78767
    X29.92630 Y15.73717
    X30.77736
    X31.62843 Y15.78767
    X32.47949 Y15.89690
    X33.33055 Y16.04703
    X34.18162 Y16.25923
    X35.03268 Y16.54176
    X35.88374 Y16.87515
    X36.73481 Y17.27440
    X36.93670 Y17.37759
    X37.58587 Y17.75185
    X38.33000 Y18.22866
    X39.28800 Y18.95947
    X39.42887 Y19.07972
    X40.13906 Y19.72826
    X40.34159 Y19.93078
    X40.99013 Y20.64098
    X41.11037 Y20.78185
    X41.84119 Y21.73985
    X42.31800 Y22.48397
    X42.69226 Y23.13316
    X42.79544 Y23.33504
    X43.19469 Y24.18610
    X43.54332 Y25.07780
    X43.81062 Y25.88823
    X44.02281 Y26.73929
    X44.17294 Y27.59036
    X44.28218 Y28.44142
    X44.33267 Y29.29249
    Y30.14355
    X44.28218 Y30.99461
    X44.17294 Y31.84568
    X44.02282 Y32.69674
    X43.81062 Y33.54781
    X43.52808 Y34.39887
    X43.19469 Y35.24993
    X42.79544 Y36.10100
    X42.69226 Y36.30287
    X42.31799 Y36.95206
    X41.84119 Y37.69619
    X41.11037 Y38.65419
    X40.99013 Y38.79506
    X40.34159 Y39.50525
    X40.13906 Y39.70778
    X39.42887 Y40.35632
    X39.28800 Y40.47656
    X38.33000 Y41.20738
    X37.58587 Y41.68418
    X36.93668 Y42.05844
    X36.73481 Y42.16163
    X35.88374 Y42.56088
    X34.99204 Y42.90951
    X34.18162 Y43.17680
    X33.33055 Y43.38900
    X32.47949 Y43.53913
    X31.62843 Y43.64837
    X30.77736 Y43.69886
    X29.92630
    X29.07523 Y43.64837
    X28.22417 Y43.53913
    X27.37311 Y43.38900
    X26.52204 Y43.17681
    X25.67098 Y42.89427
    X24.81991 Y42.56088
    X23.96885 Y42.16163
    X23.76697 Y42.05844
    X23.11779 Y41.68419
    X22.37366 Y41.20738
    X21.41566 Y40.47656
    X21.27479 Y40.35632
    X20.56460 Y39.70778
    X20.36207 Y39.50525
    X19.71353 Y38.79506
    X19.59329 Y38.65419
    X18.86247 Y37.69619
    X18.38566 Y36.95206
    X18.01140 Y36.30288
    X17.90822 Y36.10100
    X17.50897 Y35.24993
    X17.16034 Y34.35823
    X16.89304 Y33.54781
    X15.46228 Y34.00869
    X14.03151 Y34.46957
    X13.72725 Y33.26149
    X13.51590 Y32.06058
    X13.39312 Y30.87617
    X13.35358 Y29.71796
    X13.39134 Y28.55968
    X13.51405 Y27.37514
    X13.72533 Y26.17406
    X14.02956 Y24.96581
    X14.42981 Y23.76073
    X14.92769 Y22.56988
    X15.52310 Y21.40485
    X16.21415 Y20.27736
    X16.99707 Y19.19897
    X17.86628 Y18.18064
    X18.81446 Y17.23247
    X19.83278 Y16.36326
    X20.91117 Y15.58034
    X22.03866 Y14.88929
    X23.20369 Y14.29388
    X24.39454 Y13.79600
    X25.59963 Y13.39575
    X26.80787 Y13.09152
    X28.00895 Y12.88024
    X29.19349 Y12.75753
    X30.35183 Y12.71802
    X31.51017 Y12.75753
    X32.69471 Y12.88024
    X33.89579 Y13.09152
    X35.10403 Y13.39575
    X36.30913 Y13.79600
    X37.49996 Y14.29387
    X38.66499 Y14.88929
    X39.79248 Y15.58034
    X40.87089 Y16.36326
    X41.88920 Y17.23247
    X42.83739 Y18.18064
    X43.70482 Y19.20047
    X44.48766 Y20.27871
    X45.17864 Y21.40602
    X45.77402 Y22.57088
    X46.27189 Y23.76155
    X46.67215 Y24.96646
    X46.97641 Y26.17454
    X47.18776 Y27.37547
    X47.31054 Y28.55986
    X47.35008 Y29.71807
    X47.31052 Y30.87630
    X47.18774 Y32.06070
    X46.97638 Y33.26163
    X46.67211 Y34.46973
    X46.27183 Y35.67464
    X45.77395 Y36.86531
    X45.17856 Y38.03016
    X44.48756 Y39.15748
    X43.70471 Y40.23571
    X42.83561 Y41.25389
    X41.88756 Y42.20193
    X40.86938 Y43.07101
    X39.79115 Y43.85384
    X38.66382 Y44.54483
    X37.49896 Y45.14021
    X36.30830 Y45.63808
    X35.10339 Y46.03834
    X33.89530 Y46.34260
    X32.69439 Y46.55395
    X31.50999 Y46.67672
    X30.35177 Y46.71627
    X29.19356 Y46.67671
    X28.00914 Y46.55392
    X26.80821 Y46.34257
    X25.60013 Y46.03830
    X24.39521 Y45.63802
    X23.20454 Y45.14014
    X22.03968 Y44.54475
    X20.91237 Y43.85375
    X19.83414 Y43.07090
    X18.81597 Y42.20180
    X17.86793 Y41.25375
    X16.99883 Y40.23557
    X16.21600 Y39.15733
    X15.52501 Y38.03001
    X14.92964 Y36.86515
    X14.43178 Y35.67449
    X14.03151 Y34.46957
    G00 Z13.00000
    Z8.84600
    G01 Z5.84600 F350
    X31.80514 Y30.99461 Z5.74877 F350
    X31.62843 Y31.17133 Z5.70470
    X30.77736 Y31.62661 Z5.53451
    X29.92630 Z5.38445
    X29.07523 Y31.17132 Z5.21426
    X28.89853 Y30.99461 Z5.17019
    X28.44323 Y30.14355 Z5.00000
    Y29.29249
    X28.89853 Y28.44142
    X29.07523 Y28.26471
    X29.92630 Y27.80942
    X30.77736
    X31.62843 Y28.26471
    X31.80514 Y28.44142
    X32.26043 Y29.29249
    Y30.14355
    X31.80514 Y30.99461
    X31.62843 Y31.17133
    X30.77736 Y31.62661
    X29.92630
    X29.07523 Y31.17132
    X28.89853 Y30.99461
    X28.44323 Y30.14355
    X26.99227 Y30.56908
    X25.54131 Y30.99461
    X25.40499 Y30.14355
    Y29.29249
    X25.54131 Y28.44142
    X25.67098 Y28.06660
    X25.86021 Y27.59036
    X26.38199 Y26.73929
    X26.52204 Y26.57526
    X27.20907 Y25.88823
    X27.37311 Y25.74817
    X28.22417 Y25.22640
    X28.70041 Y25.03717
    X29.07523 Y24.90750
    X29.92630 Y24.77118
    X30.77736
    X31.62843 Y24.90750
    X32.00325 Y25.03717
    X32.47949 Y25.22640
    X33.33055 Y25.74817
    X33.49459 Y25.88823
    X34.18162 Y26.57526
    X34.32167 Y26.73929
    X34.84344 Y27.59036
    X35.03268 Y28.06660
    X35.16235 Y28.44142
    X35.29866 Y29.29249
    Y30.14355
    X35.16235 Y30.99461
    X35.03268 Y31.36944
    X34.84344 Y31.84568
    X34.32167 Y32.69674
    X34.18162 Y32.86077
    X33.49459 Y33.54781
    X33.33055 Y33.68786
    X32.47949 Y34.20963
    X32.00325 Y34.39887
    X31.62843 Y34.52854
    X30.77736 Y34.66485
    X29.92630
    X29.07523 Y34.52854
    X28.70041 Y34.39887
    X28.22417 Y34.20964
    X27.37311 Y33.68786
    X27.20907 Y33.54781
    X26.52204 Y32.86077
    X26.38199 Y32.69674
    X25.86021 Y31.84568
    X25.67098 Y31.36944
    X25.54131 Y30.99461
    X24.09682 Y31.42015
    X22.65234 Y31.84568
    X22.48139 Y30.99461
    X22.38634 Y30.14355
    Y29.29249
    X22.48139 Y28.44142
    X22.65233 Y27.59036
    X22.96124 Y26.73929
    X23.11779 Y26.36845
    X23.35484 Y25.88823
    X23.89594 Y25.03717
    X23.96885 Y24.94545
    X24.61721 Y24.18610
    X24.81991 Y23.98339
    X25.57926 Y23.33504
    X25.67098 Y23.26213
    X26.52204 Y22.72102
    X27.00226 Y22.48397
    X27.37311 Y22.32743
    X28.22417 Y22.01852
    X29.07523 Y21.84758
    X29.92630 Y21.75253
    X30.77736
    X31.62843 Y21.84758
    X32.47949 Y22.01852
    X33.33055 Y22.32743
    X33.70140 Y22.48397
    X34.18162 Y22.72102
    X35.03268 Y23.26213
    X35.12440 Y23.33504
    X35.88374 Y23.98339
    X36.08645 Y24.18610
    X36.73481 Y24.94545
    X36.80772 Y25.03717
    X37.34883 Y25.88823
    X37.58587 Y26.36845
    X37.74242 Y26.73929
    X38.05133 Y27.59036
    X38.22227 Y28.44142
    X38.31731 Y29.29249
    Y30.14355
    X38.22227 Y30.99461
    X38.05132 Y31.84568
    X37.74242 Y32.69674
    X37.58587 Y33.06758
    X37.34882 Y33.54781
    X36.80772 Y34.39887
    X36.73481 Y34.49058
    X36.08646 Y35.24993
    X35.88374 Y35.45265
    X35.12439 Y36.10100
    X35.03268 Y36.17391
    X34.18162 Y36.71501
    X33.70140 Y36.95206
    X33.33055 Y37.10861
    X32.47949 Y37.41751
    X31.62843 Y37.58846
    X30.77736 Y37.68350
    X29.92630
    X29.07523 Y37.58846
    X28.22417 Y37.41751
    X27.37311 Y37.10861
    X27.00225 Y36.95206
    X26.52204 Y36.71502
    X25.67098 Y36.17391
    X25.57926 Y36.10100
    X24.81991 Y35.45264
    X24.61721 Y35.24993
    X23.96885 Y34.49058
    X23.89594 Y34.39887
    X23.35484 Y33.54781
    X23.11779 Y33.06758
    X22.96124 Y32.69674
    X22.65234 Y31.84568
    X21.18293 Y32.15258
    X19.71353 Y32.45948
    X19.57703 Y31.84568
    X19.44609 Y30.99461
    X19.37626 Y30.14355
    Y29.29249
    X19.44609 Y28.44142
    X19.57703 Y27.59036
    X19.71353 Y26.97655
    X19.77269 Y26.73929
    X20.06416 Y25.88823
    X20.42342 Y25.03717
    X20.56460 Y24.73623
    X20.86721 Y24.18610
    X21.41661 Y23.33504
    X22.09319 Y22.48397
    X22.26672 Y22.29394
    X22.92776 Y21.63291
    X23.11779 Y21.45938
    X23.96885 Y20.78280
    X24.81991 Y20.23340
    X25.37004 Y19.93078
    X25.67098 Y19.78961
    X26.52204 Y19.43034
    X27.37311 Y19.13888
    X27.61036 Y19.07972
    X28.22417 Y18.94322
    X29.07523 Y18.81228
    X29.92630 Y18.74245
    X30.77736
    X31.62843 Y18.81228
    X32.47949 Y18.94322
    X33.09329 Y19.07972
    X33.33055 Y19.13888
    X34.18162 Y19.43035
    X35.03268 Y19.78961
    X35.33361 Y19.93078
    X35.88374 Y20.23340
    X36.73481 Y20.78280
    X37.58587 Y21.45938
    X37.77590 Y21.63291
    X38.43694 Y22.29394
    X38.61047 Y22.48397
    X39.28800 Y23.33628
    X39.83645 Y24.18610
    X40.13906 Y24.73623
    X40.28024 Y25.03717
    X40.63950 Y25.88823
    X40.93097 Y26.73929
    X40.99013 Y26.97655
    X41.12662 Y27.59036
    X41.25757 Y28.44142
    X41.32740 Y29.29249
    Y30.14355
    X41.25757 Y30.99461
    X41.12663 Y31.84568
    X40.99013 Y32.45948
    X40.93097 Y32.69674
    X40.63950 Y33.54781
    X40.28024 Y34.39887
    X40.13906 Y34.69979
    X39.83644 Y35.24993
    X39.28704 Y36.10100
    X38.61047 Y36.95206
    X38.43694 Y37.14209
    X37.77591 Y37.80312
    X37.58587 Y37.97666
    X36.73357 Y38.65419
    X35.88374 Y39.20263
    X35.33361 Y39.50525
    X35.03268 Y39.64642
    X34.18162 Y40.00569
    X33.33055 Y40.29716
    X33.09329 Y40.35632
    X32.47949 Y40.49281
    X31.62843 Y40.62376
    X30.77736 Y40.69358
    X29.92630
    X29.07523 Y40.62376
    X28.22417 Y40.49281
    X27.61036 Y40.35632
    X27.37311 Y40.29716
    X26.52204 Y40.00569
    X25.67098 Y39.64643
    X25.37005 Y39.50525
    X24.81991 Y39.20264
    X23.96885 Y38.65324
    X23.11779 Y37.97666
    X22.92776 Y37.80312
    X22.26672 Y37.14209
    X22.09319 Y36.95206
    X21.41566 Y36.09975
    X20.86721 Y35.24993
    X20.56460 Y34.69980
    X20.42342 Y34.39887
    X20.06416 Y33.54781
    X19.77269 Y32.69674
    X19.71353 Y32.45948
    X18.30329 Y33.00364
    X16.89304 Y33.54781
    X16.68084 Y32.69674
    X16.53072 Y31.84568
    X16.42148 Y30.99461
    X16.37099 Y30.14355
    Y29.29249
    X16.42148 Y28.44142
    X16.53071 Y27.59036
    X16.68084 Y26.73929
    X16.89304 Y25.88823
    X17.17558 Y25.03717
    X17.50897 Y24.18610
    X17.90822 Y23.33504
    X18.01140 Y23.13315
    X18.38566 Y22.48397
    X18.86247 Y21.73985
    X19.59329 Y20.78185
    X19.71353 Y20.64098
    X20.36207 Y19.93078
    X20.56460 Y19.72826
    X21.27479 Y19.07972
    X21.41566 Y18.95948
    X22.37366 Y18.22866
    X23.11779 Y17.75185
    X23.76696 Y17.37759
    X23.96885 Y17.27440
    X24.81991 Y16.87515
    X25.71162 Y16.52653
    X26.52204 Y16.25923
    X27.37311 Y16.04703
    X28.22417 Y15.89690
    X29.07523 Y15.78767
    X29.92630 Y15.73717
    X30.77736
    X31.62843 Y15.78767
    X32.47949 Y15.89690
    X33.33055 Y16.04703
    X34.18162 Y16.25923
    X35.03268 Y16.54176
    X35.88374 Y16.87515
    X36.73481 Y17.27440
    X36.93670 Y17.37759
    X37.58587 Y17.75185
    X38.33000 Y18.22866
    X39.28800 Y18.95947
    X39.42887 Y19.07972
    X40.13906 Y19.72826
    X40.34159 Y19.93078
    X40.99013 Y20.64098
    X41.11037 Y20.78185
    X41.84119 Y21.73985
    X42.31800 Y22.48397
    X42.69226 Y23.13316
    X42.79544 Y23.33504
    X43.19469 Y24.18610
    X43.54332 Y25.07780
    X43.81062 Y25.88823
    X44.02281 Y26.73929
    X44.17294 Y27.59036
    X44.28218 Y28.44142
    X44.33267 Y29.29249
    Y30.14355
    X44.28218 Y30.99461
    X44.17294 Y31.84568
    X44.02282 Y32.69674
    X43.81062 Y33.54781
    X43.52808 Y34.39887
    X43.19469 Y35.24993
    X42.79544 Y36.10100
    X42.69226 Y36.30287
    X42.31799 Y36.95206
    X41.84119 Y37.69619
    X41.11037 Y38.65419
    X40.99013 Y38.79506
    X40.34159 Y39.50525
    X40.13906 Y39.70778
    X39.42887 Y40.35632
    X39.28800 Y40.47656
    X38.33000 Y41.20738
    X37.58587 Y41.68418
    X36.93668 Y42.05844
    X36.73481 Y42.16163
    X35.88374 Y42.56088
    X34.99204 Y42.90951
    X34.18162 Y43.17680
    X33.33055 Y43.38900
    X32.47949 Y43.53913
    X31.62843 Y43.64837
    X30.77736 Y43.69886
    X29.92630
    X29.07523 Y43.64837
    X28.22417 Y43.53913
    X27.37311 Y43.38900
    X26.52204 Y43.17681
    X25.67098 Y42.89427
    X24.81991 Y42.56088
    X23.96885 Y42.16163
    X23.76697 Y42.05844
    X23.11779 Y41.68419
    X22.37366 Y41.20738
    X21.41566 Y40.47656
    X21.27479 Y40.35632
    X20.56460 Y39.70778
    X20.36207 Y39.50525
    X19.71353 Y38.79506
    X19.59329 Y38.65419
    X18.86247 Y37.69619
    X18.38566 Y36.95206
    X18.01140 Y36.30288
    X17.90822 Y36.10100
    X17.50897 Y35.24993
    X17.16034 Y34.35823
    X16.89304 Y33.54781
    X15.46228 Y34.00869
    X14.03151 Y34.46957
    X13.72725 Y33.26149
    X13.51590 Y32.06058
    X13.39312 Y30.87617
    X13.35358 Y29.71796
    X13.39134 Y28.55968
    X13.51405 Y27.37514
    X13.72533 Y26.17406
    X14.02956 Y24.96581
    X14.42981 Y23.76073
    X14.92769 Y22.56988
    X15.52310 Y21.40485
    X16.21415 Y20.27736
    X16.99707 Y19.19897
    X17.86628 Y18.18064
    X18.81446 Y17.23247
    X19.83278 Y16.36326
    X20.91117 Y15.58034
    X22.03866 Y14.88929
    X23.20369 Y14.29388
    X24.39454 Y13.79600
    X25.59963 Y13.39575
    X26.80787 Y13.09152
    X28.00895 Y12.88024
    X29.19349 Y12.75753
    X30.35183 Y12.71802
    X31.51017 Y12.75753
    X32.69471 Y12.88024
    X33.89579 Y13.09152
    X35.10403 Y13.39575
    X36.30913 Y13.79600
    X37.49996 Y14.29387
    X38.66499 Y14.88929
    X39.79248 Y15.58034
    X40.87089 Y16.36326
    X41.88920 Y17.23247
    X42.83739 Y18.18064
    X43.70482 Y19.20047
    X44.48766 Y20.27871
    X45.17864 Y21.40602
    X45.77402 Y22.57088
    X46.27189 Y23.76155
    X46.67215 Y24.96646
    X46.97641 Y26.17454
    X47.18776 Y27.37547
    X47.31054 Y28.55986
    X47.35008 Y29.71807
    X47.31052 Y30.87630
    X47.18774 Y32.06070
    X46.97638 Y33.26163
    X46.67211 Y34.46973
    X46.27183 Y35.67464
    X45.77395 Y36.86531
    X45.17856 Y38.03016
    X44.48756 Y39.15748
    X43.70471 Y40.23571
    X42.83561 Y41.25389
    X41.88756 Y42.20193
    X40.86938 Y43.07101
    X39.79115 Y43.85384
    X38.66382 Y44.54483
    X37.49896 Y45.14021
    X36.30830 Y45.63808
    X35.10339 Y46.03834
    X33.89530 Y46.34260
    X32.69439 Y46.55395
    X31.50999 Y46.67672
    X30.35177 Y46.71627
    X29.19356 Y46.67671
    X28.00914 Y46.55392
    X26.80821 Y46.34257
    X25.60013 Y46.03830
    X24.39521 Y45.63802
    X23.20454 Y45.14014
    X22.03968 Y44.54475
    X20.91237 Y43.85375
    X19.83414 Y43.07090
    X18.81597 Y42.20180
    X17.86793 Y41.25375
    X16.99883 Y40.23557
    X16.21600 Y39.15733
    X15.52501 Y38.03001
    X14.92964 Y36.86515
    X14.43178 Y35.67449
    X14.03151 Y34.46957
    G00 Z9.00000
    G00 Z13.00000
    M09
    M30
    Sep 2005
    371
    Next time post the code as a file. That would keep the screen scrolling to a minimum. <grin>
    Sent from my DROID RAZR using Tapatalk 2
    Feb 2012
    23
    Hi Vogavt,
    No worries - I'll know for next time!
    Any thoughts on my problem though?
    Cheers,
    Hamish
    Dec 2011
    30
    When you run the toolpath in the integrated madcam simulator I guess, as seeing the image, all will look good. I can see the traverse, the ramps to go down in z direction etc.
    The g-code however does not reflect the coordinates you are saying, top z=0, bottom=-5.
    Example:
    G01 Z10.01267 F350
    X29.92630 Z9.55111
    G01 Z9.17933 F350
    X29.92630 Z8.71778
    G01 Z5.84600 F350
    X29.92630 Z5.38445
    Did you know that madcam is using the absolute z levels, not the relative? So if your drawing has a top level of z=10 and a bottom level z=5, the work piece will be cut from the machine's zero point you defined for this material and then cut from z=10 down to z=5.
    What I usually do is define the machine's z=0 somewhere very high, e.g. 60mm above the vakuum table. And in Rhino I have placed my piece so its bottom is at -60mm. Hence the code will tell to cut everything from -50 down to -60.
    Feb 2012
    23
    Hi wdaehn,
    Thanks so much for your reply. With a bit of fiddling (I had the z axis reversed in Mach3! =8-0) and your info. I have sorted it! :-)
    A pefectly cut circle!
    H.
  1. Replies: 2
    Last Post: 08-16-2011, 05:30 AM
  2. Trying to understand what I need?
    By KT6G Radio in forum CNC Machine Related Electronics
    Last Post: 02-19-2010, 04:07 AM
  3. Replies: 6
    Last Post: 01-11-2009, 10:06 PM
  4. Help me understand
    By chezrad in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-22-2007, 02:26 AM
  5. I don't Understand
    By automizer in forum Phase Converters
    Last Post: 01-02-2006, 06:43 AM
