587,227 active members*
3,658 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > TSC Precharge Failure alarm 2000VF3
Results 1 to 4 of 4
    Apr 2010
    260
    I get this alarm when activating the TSC. If I hit reset the aux coolant button a few times I can get it to activate. The pump works fine and the coolant flows out the spindle. Filters are all clean. Is there a way I can increase the delay before the alarm goes off?
    www.machmachine.com
    Apr 2010
    260
    anyone know how to correct the alarm issue
    www.machmachine.com
    Jan 2007
    107
    That alarm is caused by your TRP switches not being adjusted correctly
    Oct 2009
    192
    It can also be caused by precharge pressure not being set correctly, or the valve that activates the precharge could be not functioning properly, or the shuttle valve on the TRP could be sticking.
    When the machine performs a tool change is there a knocking noise before the tool is unclamped?
  1. ATC TURRET FAILURE and ALARM
    By scadvice in forum Fadal
    Last Post: 03-29-2011, 05:36 AM
  2. MDI / RAP failure
    By s&swelding in forum Cincinnati CNC
    Last Post: 04-30-2010, 07:24 PM
  3. Leadscrew Map Checksum Failure Alarm
    By kwmkoester in forum HURCO
    Last Post: 06-03-2009, 12:58 PM
  4. VB System Failure??
    By kbillan in forum Machines running Mach Software
    Last Post: 11-20-2008, 01:01 AM
  5. EMC2 - Step/Direction Change Precharge
    By NightHawk.Eng in forum LinuxCNC (formerly EMC2)
    Last Post: 08-13-2007, 07:30 PM
