587,547 active members*
3,257 visitors online*
Results 1 to 6 of 6
    Mar 2008
    11
    Tsugami NP32 Programming
    OK, so we have this Tsugami NP32 that's been sitting in the back of the shop for the year and a half I've been here and then some. I fired it up the other day and everything seems to work fine, so I decided to try and figure it out.
    It has a FANUC control, looks like an O type.
    I'm new to these swiss types, but have been programming turning centers for a few years. Nobody where I work knows anything about the beast and all I have found are some old faded tore up manuals and oil soaked notes.
    What I am struggling with are these lines:
    G300 U-5.183 W6.4
    G50X1.147 Z-0.03
    I think that U-6.3 equals the distance from X1 axis machine origin to the centerline, but I'm not sure what you need to do to calculate what this value will be from part program to part program. Same with the G50 line.
    You see, I'm used to "regular" turning centers. When I switch part programs I set the G54 to program zero and typically face off the part and then touch off my tools to this face (program 0). I'm guessing that these lines perform a similar function?
    I'm missing something on these swiss machines, perhaps I need to change my thinking.
    Come to think of it, I'm not sure how I would touch tools off, but I really haven't got that far yet.
    If anybody out there is familiar with this machine or one similar and can offer any advice, both in the programming and or setup, I would be forever in your debt.
    Jan 2005
    304
    I used to run that machine many moons ago. I run swiss now just not that model.
    Swiss are a"different" breed. You will need to change the way you think. These machines work GREAT but you need to accept the way the machine thinks and work with it that way or it will drive you crazy.
    The machine works like a "cam" machine. All the tools and axis' are put at a "Starting Position" at the start of the program and return there at the end of the program. This is done using the machine coordinates and work shifts
    (G50).
    The "G300" line you mention is how this machine goes to "start Position". This is the part length and tool "geometry" added together. The is done with the collet open so the stock does not move during the motion. The barfeeder holds it in place.
    The "G50" line sets the work coordinate system for the part before any movement of a tool or axis.
    The setting of tools for that machine was done with a "pesetter". The whole thing works from a theoretical zero position.
    The "Z" axis is the opposite of a cnc lathe. This is because the stock is moving across the tool not the tool across the stock.
    This is just a very brief description, you should seek better help from Rem Sales to be more successful.
    Good luck! Welcome to the "DARKSIDE"
    Feb 2009
    52
    I need all manuals of tsugami np 32. Is there anyone who is having it?
    Aug 2010
    I have all of the manuals that I think you are looking for, I am not too good with this site so if you e-mail me at [email protected] I will attach them and return them to you. Good luck with this machine it was a true work horse for its time,and if you need any advice on service or repair I might be able to help.
    Apr 2012
    6
    Quote Originally Posted by Doctor Tsugami View Post
    Hello, I have a Tsugami CNC lathe NP-32 and need their manual . I have sent email to you. Could you please help me these manual. Thanks so much
    Apr 2012
    34
    Re: Tsugami NP32 Programming
    sir I have the same machine. we just got it running. can you please help me with the M codes
    thankyou
  1. programming citizen versus tsugami
    By Saturn2000 in forum CNC Swiss Screw Machines
    Last Post: 07-11-2014, 03:08 AM
  2. programming citizen versus tsugami
    Last Post: 05-19-2014, 05:10 PM
  3. TMU Tsugami
    By Spaluz in forum CNC Swiss Screw Machines
    Last Post: 08-10-2013, 11:26 PM
  4. Tsugami s25
    By eameddie in forum CNC Swiss Screw Machines
    Last Post: 01-14-2013, 07:14 PM
  5. Tsugami T-SPD
    By rmcclane in forum Want To Buy...Need help!
    Last Post: 10-25-2008, 08:20 PM
