587,842 active members*
3,393 visitors online*
    Apr 2005
    460
    Tsugami PL3B Help
    I have a PL3B gang slide flat bed lathe that has spindel bearing's that are noisey and I would like to rebuild the headstock I don't have a manual that has a breakdown illistration of the HS look's preaty simple I can remove it from the base or work on it where it sit's I'm working on the tin right know paint ect would be a good time too tear into it with the sheetmetal out of the way REM checked with the factory and they have a part's manual end a operator's manual about $600.00 for the pair I have the operator's man. and I asked If they could Email a pic of the spindle breakdown I was hoping that some one might have some insite on this subject Wiring print's would be helpfull espicaly for the Mfunction relay's Thank's Kevin
    Sep 2009
    21
    Ever get anywhere on manuals for this machine? I just bought one and am looking for the machine manual and am having no luck.
    Jeff
  1. M codes for Tsugami
    By guhl in forum G-Code Programing
    Last Post: 07-12-2019, 05:19 PM
  2. Thoughts on Tsugami
    By timan in forum CNC Swiss Screw Machines
    Last Post: 03-28-2015, 01:19 AM
  3. Tsugami T-SPD
    By rmcclane in forum Want To Buy...Need help!
    Last Post: 10-25-2008, 08:20 PM
  4. Threading on Tsugami BS 32C
    By ACME guy in forum Want To Buy...Need help!
    Last Post: 05-17-2008, 09:31 PM
  5. M codes for Tsugami 10T
    By guhl in forum Fanuc
    Last Post: 12-01-2007, 01:52 PM
