603,785 active members*
18,791 visitors online*
Results 1 to 7 of 7
    Sep 2005
    540
    TTS Adapter Collars
    Here are some TTS style adapter collars I made this morning. They are modified 6435K16 collars from McMaster and appear to work really well. Cost around $2.00 each and a few minutes time with the lathe.
    Robert
    Apr 2006
    439
    Nice Robert !!
    Thanks for the part # Looks like a pretty handy thing to have on hand . I will include a few the next time I order from them.
    Scott
    www.sdmfabricating.com
    Sep 2005
    540
    Appreciate the comment Scott... Hope it is helpful in some way.
    Robert
    Feb 2008
    154
    That's great, thanks for sharing. I assume you cannot use them at high rpm right?
    Sep 2005
    540
    The Tormach std spindle is not really what I would call high speed. I don't see much difference between these and the TTS end mill holders as neither are balanced.
    You are correct, I would not use them or the TTS EM holders in say a 10k+ spindle with out being balanced. One needs to use common sense in these matters.
    Robert
    Feb 2008
    154
    Actually, I have used some TTS endmill holders at 10000rpm with my 770 with no issue. I doubt that these collars would break at 10000rpm but it would vibrate badly enough to make it worthless at these speed. Still very useful for bigger and slower tool.
    Quote Originally Posted by RTP_Burnsville View Post
    Robert
    Jun 2006
    2512
    Did I read somewhere that Tormach could supply balanced TTS for use in the 770?
    Phil
    Quote Originally Posted by concombrefrais View Post
  1. Adapter for VME-Bus
    By Holzwurm56 in forum CNC Machine Related Electronics
    Last Post: 05-22-2010, 04:16 PM
  2. Usb Adapter
    By nuzzget in forum Controller & Computer Solutions
    Last Post: 07-31-2009, 04:06 PM
  3. PC-MPI ADAPTER
    By CHANDRU in forum CNC Machine Related Electronics
    Last Post: 12-14-2007, 12:06 PM
  4. 3/8 to 1/2 adapter
    By TMaster in forum Benchtop Machines
    Last Post: 07-29-2006, 12:15 PM
  5. Tool offset collars?
    By mgamber in forum Benchtop Machines
    Last Post: 09-13-2005, 07:16 PM
