I am having a world of trouble getting my servos tuned. My focus is on Y at the moment. With the servos powered off the pulley/ballscrew turns easily by hand. The servos are from IH (part of the kit). They run the saddle in choppy steps. With an occassional smooth inch or two. Gib is totaly loose.
Limiter when turned all the way off disables the servo. When turned to 55 or 100% the behavior is the same.
The choppiness is during continuous jog or GO/G1 gcode moves.
For grins, I hooked up a an electric drill to the ball screw shaft and it moves the saddle in and out smoothly. Servo just doesnt seem to spin very fast.
I measured input voltage to the Gecko and it was 76 volts (spot on).
I have read about tuning on this forum and the Mach forum. I just dont get it. Gecko faults at anything over 50 IPM. Another clue is Mach thinks the feed rate is near where it is set (based on its feed rate display). But timing it by hand shows it running much slower.
Chris
