603,929 active members*
2,640 visitors online*
Results 1 to 7 of 7
    Nov 2003
    287
    Turck Proximity Sensors
    I have a surplus of these Truck Sensors around and was curious if they could be wired to a BOB. Not really sure on there data.
    Attachment 217194
    Dec 2003
    24260
    Link does not work, what is the model No?
    Al.
    Albert E.
    Nov 2003
    287
    Al,
    Turck # NI-4-G12-AZ33X-B3131 ID # 1304232
Name:	Turk prox1304202 (sheet_1).pdf
    Dec 2003
    24260
    Those are 2 wire N.O. AC/DC type, so they should work on any input from +10vdc and up.
    Polarity should not matter.
    Al.
    Albert E.
    Nov 2003
    287
    So the third wire (green) is just ground or is it used for power?
    Thanks for the help.
    Dec 2003
    24260
    Earth Ground, not power ground (common).
    Al.
    Albert E.
    Nov 2003
    287
    Ok. Thanks I will give them a try.
  1. Turck proximity sensors
    By hacker7 in forum DIY CNC Router Table Machines
    Last Post: 11-02-2013, 05:27 PM
  2. proximity sensors
    By FordGalaxy in forum Benchtop Machines
    Last Post: 06-02-2012, 09:36 AM
  3. proximity sensors for homing or thc?
    By Wolfesmetalfab in forum CNC Machine Related Electronics
    Last Post: 12-03-2008, 07:30 AM
  4. proximity sensors
    By wired in forum CNC Machine Related Electronics
    Last Post: 09-30-2005, 05:29 PM
  5. capacitive proximity sensors
    By owhite in forum CNC Machine Related Electronics
    Last Post: 03-16-2004, 03:49 PM
