603,344 active members*
3,639 visitors online*
Results 1 to 9 of 9
    Jul 2005
    17
    Turning 4130 steel?
    Hello all. My problem is turning a tube 35" long, .812 ID with a .077 wall thickness. I worked with the machine seller over 6 weeks to finally get it running without chatter. The machine is a brand new Daewoo 2500 dual turret. I'm using a steady rest, hydraulic and self centering. RPM is 1350 Feed is .0085 IPR and depth of cut is .060 roughing and .015 finish. The finish is pretty good but I can't get the chips to break during roughing or finish cut. I get 8 to 12 inch long chips that are like springs. I have thousands of parts to mfg. and I know it's only a matter of time before the steady rest tangles one up. I am machining these parts on a hardened arbor. When I ship a few hundred parts to my customer I'll be able to shave some time off these parts (right now 19min) by doing some R+D with inserts and speeds and feeds. If anyone has machined 4130 before and has any ideas how to break a chip, I hope you'll post your ideas. Thanks.
    Oct 2003
    352
    Change your roughing insert to a positive geometry rather than a negative geometry. Negative inserts are not good for thin walled parts due to push off and such. Play around with your feeds and speeds to get a tight little chip. I cut 4140 HT all day long but you have to push hard to get a chip. The positive insert will shear the material rather than rub it raw which leads to stringy shavings. How do you like the 2500? Is it the TL or the TT? I am thinking about buying a TL2500.
    Mar 2003
    4826
    If you are still in an experimenting mood, I'd recommend that you try the Iscar cutgrip tooling. In my experience, it does not necessarily break the chip, however, they can roll the chip into a nice smooth, tight coil about 3/16 to 1/4" diameter, and the coil may break when about 6" long.
    Do the cut in one pass. The Iscar cutgrip is capable of excellent finish at a feedrate of .01 but be aware that setting of the tool is critical to prevent chatter. The cutgrip insert leans ever so slightly away from the cut direction due to the force of cutting, and this creates the insert clearance. So the tool must be set so that this tipping of the insert does not cause it to hog in along the broad nose. Only the corner does the cutting.
    I used to turn .350 dia 304 stainless tubing down to .245 OD, leaving a .005" wall thickness with these inserts, one pass only. I also used a mandrel inside the tube for support. Turned length was 5.5", and cnc made it possible to program a gentle arc to counteract the flex of the part, as I had no steady nor follower for this process. I turned several hundred of these, finally I got smart and had tubing custom made for the application
    First you get good, then you get fast. Then grouchiness sets in.
    Jul 2005
    17
    looking at tooling now
    thanks guys, i'm going to check out iscar's tooling this week. my customer is our uncle sam, he ain't changin' nuten'. i'm using a TL it's pretty good. hydraulics on demand is nice and quiet.
    Sep 2006
    54
    I would use a #1 radius tool for chatter problems. 4130 is a little more gummy than 4140, I would probably try a .008-.01ipr feedrate. Also I would try to keep the two cuts equal depth to maintain a chipload on the tool. At .015 finish, I would assume that it wouldnt break a chip very well at all. As far as rpm I would try around 400-600 sfpm. This is where I would start but might end up right where you are. Hope this helps
    Jul 2012
    118
    Re: Turning 4130 steel?
    i know this is a hella old thread, but bring this one back, verses starting a new one. have problems getting good finish on face of part. i have followed suggestions from here, and im close. ok details. using Haas st30, iscar wnmg 431-tf ic3028(i know, not the best, but my general steel insert). im running about as fast rpm as im willing to go. have tryed changing how much i leave on the face to with no luck.
    here is the program:
    N1 T202 (WNMG)
    G54
    G50 S2700
    G96 S750 M03
    M03
    M08
    G18
    G00 X1.78 Z0.085
    G71 P17 Q26 U0.025 W0.01 D0.05 F0.01
    N17 G00 X0.
    G01 Z0. F0.006
    X1.2485
    X1.2752
    G03 X1.2902 Z-0.002 R0.015
    G01 X1.595 Z-0.09
    G03 X1.61 Z-0.103 R0.015
    G01 Z-0.265
    Z-0.365
    N26 X1.78
    G70 P17 Q26
    M09
    G00 X10. Z10.
    T200
    M01
    thanks in advance
    Dec 2011
    34
    i would try finishing the face feeding down from big dia to small dia,then reposition tool and come back and finish the od turn.id say leave about .015 for od finish and .002 for face finish.feed @.0053.this has worked well for me.check out mepro too.itll help get in the ballpark for finish requirements.
    Jul 2012
    118
    bump for help
    Jul 2012
    118
    Quote Originally Posted by MetalCarpenter View Post
    thanks man, ill try that.
  1. turning 4130, 4140
    By Stifler51 in forum Material Machining Solutions
    Last Post: 03-27-2010, 11:37 PM
  2. Questions about 4130 chromoly steel
    By nicolacycles in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-15-2008, 03:27 PM
  3. Milling 4130 Steel
    By JWB_Machining in forum MetalWork Discussion
    Last Post: 11-06-2008, 06:04 PM
  4. RFQ: 4130 turning work
    By stanglou in forum Employment Opportunity
    Last Post: 01-20-2008, 05:15 PM
  5. 4130 Steel
    By FAMOUSX1 in forum Material Machining Solutions
    Last Post: 10-12-2006, 05:16 PM
