588,215 active members*
4,078 visitors online*
Results 1 to 10 of 10
    Turning down acme thread rods
    Does anyone have any ideas or suggestions on how I can turn down the ends of acme rod so it will fit the inner diameter of roller blade bearings.
    I don't have a lathe and would like to know if there are any diy methods that will produce good enough results.
    I like the setup that eric (balsaman) used on his cnc router lead screws.
    Nov 2003
    634
    I had mine turned by a machine shop, but since yours are already turned you might want to consider just getting the appropriate bearings. I bought some from Ebay. There is a guy there that sells almost every size you could want for a very reasonable price.
    T
    Mine aren't turned yet.. that is just a pic I snagged from another posting.
    How much did the machine shop charge you to do yours?
    Nov 2003
    634
    Its a shop that I send alot of parts to from work, so he turned my screws down for free as a favor.
    I'd guess that it would cost $50 to $75 total for 3 screws.
    T
    Jan 2004
    490
    Chuck it into a drill, hold end with UHMW or wood, spin drill with foot while holding a file to the screw. Takes a long time, but is free! If I get some time this weekend, I'll draw up plans for an idea I've had for just this purpose. Sort of a poor mans lathe. If I'm lucky, I may get the time to build one!
    Stop talking about it and do it already!!!!!
    Jun 2004
    34
    Too, too funny. What a picture!
    Smile, life is too short to sweat the small stuff.
    John M. Stuedle
    The Shop Out Back Aviary
    Jan 2004
    490
    It works...really! Never got the time to try the other idea though. Don't even remember it now!
    Apr 2003
    307
    Get some bearings that slide onto the rod. Make a fixture out of mdf that will hold the bearings and the leadscrew horizontally so it will spin in the bearings. Use a drill motor to turn the rod. Then attach the fixture to your CNC machine. Use a grinding wheel in a grinder to turn the ends down in light passes.
    Hopefully you aren't tearing your machine apart and can still use it.
    Chris
    May 2004
    83
    Park your car next to a curb. Jack up either the front or rear, depending on whether its FWD or RWD. Weld end of acme rod to approximate center of wheel. Start engine and put in gear to start wheel and rod spinning. Slowly lower jack until rod grinds against curb. Use foot (with stout shoe attached) to step on rod and feed it into the curb. When finished, drive car to supplier and buy more rods. Drop them off on the way home to a machine shop who can turn them to size and maintain concentric diameters so they don't flop around like an epileptic bullwhip when you install them on your machine.
    Mar 2004
    1306
    LMAO!!
    Kurt (The Swede) has a write up of the right way to do this here:
    http://www.5bears.com/cnc16.htm
    Still need a lathe though.
    Regards,
    Mark
  1. Thread milling, can anyone help
    By jtrav in forum Uncategorised CAM Discussion
    Last Post: 03-06-2006, 09:25 PM
  2. 304 stainless steel slide rods
    By bertvk in forum DIY CNC Router Table Machines
    Last Post: 09-25-2004, 10:35 PM
  3. what acme tap do I need for the Enco ACME rod?
    By AJ_Mac2001 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2004, 02:24 PM
  4. Manual thread turning handle
    By JFettig in forum Uncategorised MetalWorking Machines
    Last Post: 03-05-2004, 01:46 PM
  5. Thread milling cutterdia / hole ratio
    By HuFlungDung in forum DNC Problems and Solutions
    Last Post: 01-01-2004, 03:44 AM
