588,487 active members*
5,374 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Turning On Mirror Image Fanuc 18-m Control
    Aug 2005
    57
    Pleaaseee Help Me Figure Out How To Mirror Image X & Y To Flip My Axis.......
    Mar 2003
    2932
    You should be able to go to OFFSET/SETTING, then [SETING] cursor to the axis you wish to mirror and change the 0 to 1.
    Mar 2006
    33
    I tried to turn on mirror image a couple of ways, I maybe think there is also a parameter you can change which does the same thing, but had no luck with either method. The machine mfg. support rep didn't understand it either.
  1. MIRROR IMAGE WITH MY FANUC 18-M
    By PICMAN in forum Fanuc
    Last Post: 08-05-2009, 02:10 AM
  2. mirror image
    By cp465vw in forum Machines running Mach Software
    Last Post: 04-14-2009, 04:39 AM
  3. Mirror image
    By rbach in forum Mach Mill
    Last Post: 01-20-2009, 06:58 AM
  4. Everything comes out as mirror image
    By rbach in forum Controller & Computer Solutions
    Last Post: 12-21-2008, 06:46 AM
  5. MIRROR IMAGE HELP
    By TOM R in forum CNC Machining Centers
    Last Post: 12-01-2008, 09:01 PM
