603,919 active members*
2,350 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Turning stepper motor without driver?
Results 1 to 5 of 5
    Oct 2010
    I need a slow turning motor for a small project, and a stepper motor sounds like the best bet, but I don't have a spare driver...
    I have a few small DC and AC motors, but they spin too fast and when I slow them down they have next to no torque.
    So, is there any way to use a 12 volt power supply and a POT switch to spin a stepper? I haven't tried randomly hooking it up as I didn't want to damage the motor if someone here had an easy answer for me.
    Thanks, Taylor.
    Dec 2003
    24260
    A DC motor generally has highest torque at zero RPM, same as a stepper?
    What are you controlling it with?
    Al.
    Albert E.
    Oct 2010
    Quote Originally Posted by Al_The_Man View Post
    Al.
    A POT on the AC motor, and ESC on the DC ones. They stutter when I have them turned down, so maybe they just don't have enough torque then. My original idea was to gear it down, but I don't have enough room to do much gearing and that was when I thought of the stepper.
    Jan 2005
    1943
    If you have a couple spare steppers, hook the wires of the two steppers together and turn one. The other will also turn.
    You can run a step motor from 12VAC. One winding connects to the transformer secondary while the other winding must have a capacitor in series with it when connecting to the secondary. The motor will turn at 72 RPM in the US (60Hz) and at 60 RPM in places that have 50Hz AC.
    Mariss
  1. Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A
    By guy2b1 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2011, 12:50 PM
  2. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
  3. Integrated stepper motor? with built-in stepper motor driver
    By uirobot in forum News Announcements
    Last Post: 06-07-2010, 09:59 AM
  4. Beltdrive-stepper motor-stepper motor driver
    By Georg in forum Stepper Motors / Drives
    Last Post: 10-16-2007, 10:56 PM
