588,500 active members*
5,143 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > turret position, romi lathe, control fanuc 0i mate TB
Results 1 to 5 of 5
    Sep 2008
    93
    I have romi machine (lathe G280)
    fanuc 0i mate TB
    the turret rotation is controler with servo amplifier A06B- 66093-H152
    Do you have the manual for the servo amplifier?
    I have changed the batery in the servo amplifier, and the turret lost the absolute position.
    how fix it?
    do you have any procedure for zero point?
    Dec 2012
    395
    Hello,
    For the Beta Series AC Servo Motor, manual GFZ-65232EN/02 ( A06B-6093-H152 and more ), check next website;
    http://www.prodsa.com.ar/integradore...LS/65232EN.PDF
    For the Beta Series Servo Motor I/O Link Option, manual GFZ-65245EN/01 ( A06B-6093-H152 and more ), check next website;
    http://fanuc.pennineuk.com/library/p...cbetadrive.pdf and http://fanuc.pennineuk.com/a06b-6093-beta.htm
    Regards,
    Heavy_Metal,
    The Netherlands.
    Jan 2013
    37
    Re: turret position, romi lathe, control fanuc 0i mate TB
    I have the same amp with same problem. The links to reference zero do not work. Does anyone else have the procedure?
    Dec 2009
    977
    usualy the beta driver for the turret is linked to power mate manager alias PRG MATE,PMM Manager
    The power mate menu you will find by going with the right arrow
    when you enter the Power Mate manager you need to go to system and paramters and the paramter for the zero is the parameter 11 bit 0
    When you loose the reference that bit will be 0 so you need to make it 1 on the tool number 1
    So be sure that the tool umber 1 is the working tool and make that parameter 1
    Power off/on and you should be good
    Jan 2013
    37
    Thanks for the info. We are up and running!
  1. Replies: 1
    Last Post: 06-02-2020, 04:58 PM
  2. home position for fanuc 0i mate model C
    By beth_piyik in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-23-2011, 10:03 AM
  3. Lost Parameters on Fanuc Position Mate
    By MICK DAVIS in forum Fanuc
    Last Post: 09-19-2008, 11:34 AM
  4. Replies: 1
    Last Post: 10-19-2003, 02:34 AM
