603,794 active members*
2,474 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach Slant Lathe > Turret and Tool Live Graphics Preview Question
    Jan 2006
    179
    I have PathPilot 1.9.8 running on the SlantPro with the Turret. While running an OD turning cycle generated from the conversational programming, in the live graphics preview the tool tip appears to be approaching from the operator side (-X) side of the machine, covering the part, whereas in reality it is approaching from the uphill (+X) side with the turret. I could have sworn in the old version of PathPilot I had (really early version) that the orientation of the tool int he live graphics preview was correct. Is there something I have wrong, or is this a known bug?
    Also, does anyone know how to run a graphics preview of a program without actually making the machine move? That would be sweet if that were a feature, but I don't think that it is.
    Sep 2008
    325
    Re: Turret and Tool Live Graphics Preview Question
    Make sure the machine origin is set correctly to the part as it would be on the machine.
    I don't know of a way of running a live preview on the display without running the program. I sometimes initially set my origin far enough in the Z + so the tool cuts air.
    Aug 2014
    257
    I’m pretty sure you can simply revert back to the prior version simply by updating to it.
    Quote Originally Posted by sanddrag View Post
    A little less known aspect to PP is that it can be run in Virtual Box. When doing so you can simulate any of the machines available. PP knows when it operating in VB & allows you to configure the desired machine for simulation.
    So on my desktop I can run PP in a virtual box, load my program, and actually see how it’s going to perform. I do this for both my 1100 & Slant-Pro – works very well.
    You really want to run the latest version of Virtual Box 5.1.22 when doing this.
    Attachment 364638
  1. Replies: 0
    Last Post: 04-10-2013, 07:19 PM
  2. BMT Turret Live Tool Design Concept
    By selvaraj205 in forum Mechanical Calculations/Engineering Design
    Last Post: 05-26-2008, 04:03 PM
