587,990 active members*
5,437 visitors online*
Results 1 to 5 of 5
    Jan 2005
    59
    Question Two Hose machine torch set up for oxy fuel?
    I was told that I only needed a two hose machine torch to set up oxy fuel on my cnc plasma table. So I got a used Victor MT200C and now I'm starting to question if this was the right decision.
    I want to set up a simple manual peirce system, where I allow motion to the peirce point, Mach3 pauses, I wait for the preheat time and then manually turn a valve for the cut oxygen and then hit run and it drops to cut height. Real simple as I wont be doing alot of oxyfuel cutting, mostly plasma.
    So can I do this with a two hose torch? I see my torch has some kind of valve on the side in addition to the valve on each line, but I can't find out any info on what this does. Is it a on off valve for the cut oxygen?
    Can I just put two regulators on the oxygen line, one for preheat and then another for cutting that can be controlled with a valve.
    Or is it best just to sell this and get a three hose?
    Any help would be apprecited.
    Mar 2009
    924
    Sorry double post!
    www.metaltechus.com
    Mar 2009
    924
    There is really no simple way to activate a two hose torch for use on CNC. A three hose torch will need a solenoid at some point in the line to trigger the cut oxy. The closer to the torch the better, you will have less post flow time. You will need a signal out to open the solenoid too.
    ****use caution on the solenoid, make sure it is oxy safe****
    Check out this thread:
    http://www.cnczone.com/forums/cnc_pl...iscussion.html
    WSS
    www.metaltechus.com
    Mar 2013
    26
    Re: Two Hose machine torch set up for oxy fuel?
    Hi, I think you should go for a 3 hose torch.
    Sep 2005
    1195
    You can use 2 hose torch like I do, but need a lot of practice. I cut 5 mm steel plate some time have a good result, some time not. Depend on parameter and material clean or not.
  1. Torch height controller for oxy fuel
    By scrambled in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 06-04-2016, 10:03 AM
  2. Oxy fuel torch recommendation needed
    By mcv300 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 08-28-2013, 02:26 PM
  3. Torch type/Oxy fuel gas options?
    By jason_alex in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 07-23-2013, 09:32 PM
  4. hypertherm 1000 hand torch to machine torch
    By duraflap in forum Hypertherm Plasma
    Last Post: 05-18-2010, 08:34 PM
  5. Info needed on triple-torch beveling on Alltra Oxy-Fuel flamecutter
    By hatchmar in forum Waterjet General Topics
    Last Post: 04-20-2009, 10:01 PM
