603,930 active members*
5,085 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller Cards > Two stm32f103 boards Firmware MOD-UPGRADE for laser etcher-cutter CNC 3D printer HELP
Page 2 of 2 12
Results 21 to 30 of 30
  1. #21
    Nov 2011
    3
    Re: Two stm32f103 boards Firmware MOD-UPGRADE for laser etcher-cutter CNC 3D printer
    Hi everyone.
    To change my CNC from parallel interface to USB interface I bought the BSMCE04U module.
    But with difficulties in understanding how to connect this module, I decided to draw its schematic.
    Below is a copy of the schematic for those who want to visualize how this module is internally
    to better understand its functioning.
    Some capacitors could not identify the capacitance.
    Please, if you find errors, please let me know.
    RV mineirin
  2. #22
    Apr 2004
    217
    This project I have set aside for some time, I'm working on other projects that are more important currently. Ruibarbazul I see some differences in the pin assignments. I believe you are correct and what I posted is in error thanks. I have X one of the X pins going to PA not PB, which would make code very hard. hum that changes things. I dont have time to work on this project currently, maybe someone is working on STM32 GRBL and could help with coding for this board.
  3. #23
    Mar 2021
    3
    Hello,
    I will port GBRL STM32 code ( https://github.com/whoim2/stm32-bluepill-grbl-pcb ) to the bsmce04u-pp but first of all I want to maintain present firmware. There fore I have quiestion If anybody have downloaded firmware from STM32? I assume that there is protection bit but based on variety of bsmce04u-pp clones maybe not.
    @Ruibarbazul Can You post sch file instead of jpg?
  4. #24
    Mar 2021
    3
    1) I have some idea how to make this board works both as Mach3 and GBRL controller. STM32 have NRST pin so it is possible to halt originally soldered mcu and on the top of it connect (some kind of sandwich “chip-on-chip” simple PCB with programmed STM32F103 - GBRL firmware + chip selector).
    The firmware is easiest thing but I have to figure out how to connect this second mcu. I have idea to design sandwich socket like in old Amigas but there is no sold thing and have to design own (unless I am better software developer than mechanical). :/
    2) Other solution is to design own board with both mcu and resolder oryginal form bsmce04u-pp
    @Ruibarbazul Can You share Your chematic as sch file?
  5. #25
    Apr 2007
    4
    Quote Originally Posted by SileliS View Post
    1)
    Whilst browsing this site I stumbled upon this most interesting thread. I was wondering whether this idea has been developed since last year's contribution.
    The last contribution proposed installing a second mcu on top of the existing in order to carry out the development?
    With the price of these boards at a mere $5 or so, wouldn't it make more sense to simply buy a second board and overwrite the existing software. If this cannot be done because the chip is write protected it seems easier to replace the STM32 with a new one instead of installing one on top.
  6. #26
    Jun 2007
    150
    There is a nice firmware on github which upgrades this board from mach3 to ugs, you just need the 4 wire usb programming tool from ebay, maybe $5usd.
  7. #27
    Apr 2004
    217
    xuraax xuraax. Hello sorry I have been more or less MIA from everything for a long time. My father battled stage 4 cancer for 5 years. I got caught up being the """"only"""" one of his many children to aid and take care of him. Problem is that he became a very angry person with bitter bitter BITTER BITTER denial of his failing health. Do to his many ill with intent choices. Produced very harsh financial issues for me. I've more or less lost almost $ almost everything. And its not over by a long shot as of the posting date of this post.
    As to the board. I was able to access the board, but I was not able to recover a copy of the original virgin firmware for mach3. On the other hand I was able to clear and program the stm32 with simple hello world test code. I am NOT much of a programmer. I'm a designer and hardware person. others will have to design and compile the code. I would love to see these boards with marlin or stm32-grbl LOADED. you may find this photo link of mine of interest. https://photos.app.goo.gl/ZVxFnvZABBCnJGsW9 Also I wish someone would produce and publish GRBL for the new arduino uno r4. It would be a drop in massive upgrade for my laser etcher.
  8. #28
    Apr 2004
    217
    elmerfud got a link to the mach3 to usg github your talking about? I'd love to look at it.
  9. #29
    Apr 2004
    217
    I found the link https://embeddedtronicsblog.wordpres...is-bsmce04-pp/ was talking about elmerfud.
  10. #30
    Apr 2004
    217
    I'll post some photos at some point in time, but I am currently using this controller as a GRBL controller on my new large cnc machine. Its not my choice in controllers for this machine, I'm using it because the other controller I have failed and I have too much going on in my life to deal with getting a replacement. In any case using my MOD that I have described in this thread. Using the STM32 PRORAMMING adapter the ST-LINK adapter. and using the code from the last post I was able to load the GRBL control image onto the board. Please be aware there are different versions of this red "mach3" control board. At its core its just an STM32 nothing special. I have the BSMCE04U version that does not have a programming header. This entire thread describes where the data lines are so you may program it. Please be aware removing the original code (mach3 firmware) can not be un-done. The version of this board that comes with a 4 pin programming header is a stupid simple version to deal with. Use an ST-LINK adapter, download the grbl firmware load it and happy days. The version of the board with out the header, You must solder wires to the critical via's for programming. Once the grbl firmware has been loaded, the board is now a full stm32 based 32bit grbl 4 axis motor controller. My biggest difficulty has been the learning curve solving the "inversion" settings to get all of my driving signals be they in or out high or low to be as needed for my hardware. All in all I am pleased with this board. In the long run I'm not sure what I will use this controller for, mainly because its lacking all the advanced gcode mcode control code like the mesa controllers and planetcnc controllers have. If anything maybe I'll use this controller in the long run on a new laser machine? I would use it on my current laser machine but I need an arduino UNO foot print and logic level compatible solution. A drop in that does not require extensive modification. Sadly the arduino uno r4 is on paper a DROP IN. but no one has developed GRBL for it. The wemos d1 r32 looks like its a drop in, and I have found links with people using the arduino uno motor HAT. But :S not sure I trust it.
Page 2 of 2 12
  1. How can I upgrade my firmware in my General CNC I-carver machine?
    By netrate in forum Commercial CNC Wood Routers
    Last Post: 11-18-2020, 03:00 AM
  2. I've just bought a Chinese laser / etcher 60watt with an 8o watt upgrade need advice
    By evans in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-04-2018, 03:32 AM
