New 2006 projects just posted in catalog. More to follow. U-Build Metal Turning lathes & attachments, Low cost EDM, Milling & Grinding Attachments, Roller Guide for Hand Filing, Dual Tool Post Grinder (Internal & External), Form Turning Tools,Small Lathe Taper Attachment, Caseharden Iron & Steel, Two Simple Die Holders, Add a Limit switch to Lathe Carriage, Lathe Metal Shear, Nonfriction Metal Spinning Tool (Designed to spin with the work), Build Your Own Riveting Press, Bandsaw 10:1 Inexpensive Speed reducer, New Low Cost Spindle Grinder for Lathe, Step-Collet Chuck, Pin Cutter Attachment for Lathe, Home Shop Etching & Electroplating, Back Bit Holder uses Upside-Down Tool Bits, Much, Much, More! Visit catalog at: www.poormanspubs.us and see for yourself.
