Im using a 14mm 4xd u drill on an SL10 and am getting a 0.010" oversize hole on mild steel, 0.040" o/size on stainless steel and im also getting a pip in the centre of the hole. It does look like the web with the inside insert is rubbing as there are a few marks on the web. I placed a clock in the chuck and clocked around the dia of the shank and it was within 0.004". Is this too much? The turret is also 0.004" out over 3 1/2" in the x axis after a crash when i first got the machine. The thing is i have been using a 20mm u drill for years and have never had this problem with it. Could the u drill be vibrating too much and causing the issue?
