603,982 active members*
2,638 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > U & V address in CNC Programming
Results 1 to 5 of 5
    May 2009
    393
    Question U & V address in CNC Programming
    Hi
    What do the U & V addresses refers to..
    I have 1 turning centre & it defines the incremental distance in the absolute mode...
    like....
    G90
    G00X0.0Y0.0.............An absolute position on the Part Zero
    G01U50.0..................Will move to X50.0 (In absolute terms)
    G01X100.0...............Here the tool will move 50mm from the previous location...
    Well thats what i interpretated about U,V & W.
    But on turning centre it works absoulte Ok,
    The problem is on Pinnacle machine (VMC) it shows an P22 alaram..what must be the thing....or is that so in machining centre, such U V & W are not configured.
    pLEASE CORRECT ME IF I AM MISSING SOMETHING....
    Dec 2003
    24260
    Some older machines used U,V,W for an incremental or relative move of the X,Y,Z axis.
    Absolute move would use the X,Y,Z notation.
    Later machines use G90 G91 for Absolute and Incremental.
    You would have to refer to the control manufacturers literature to find out which is relevant.
    Al.
    Albert E.
    May 2009
    393
    Quote Originally Posted by Al_The_Man View Post
    Al.
    K...........
    Thanks for that info.....
    Nov 2005
    172
    On most turning centers I deal with the incremental commands are (U) for "X", (W) for "Z" and (H) for "C". The primary advantage from my perspective is when generating gode at the machine. It provides you a quick method of moving the machine (example - relieving a tool after a cut) without having to "do the math".
    These are also addresses within numerous canned and multiple repetitive cycles within many controls.
    Hope this helps.
    Mark T.
    May 2009
    393
    Quote Originally Posted by MarkT View Post
    Hope this helps.
    Mark T.
    Ok....Mark....
    So is that so that U & W are used mostly on turning centre... Does they exist on a machining centre...???
    Sometimes i feel that that these Address used for axis defination are so confusing....For example, "U axis is a relative movement in a turning centre & the same U axis is a taper cutting axis on WireCut"....These Manufacturer have clubbed address so it hard for anybody to interpret it easily..............Well just wanted to express manufacturer's desire...........:drowning:
  1. Set IP address in Arrow 500.
    By yuvalron in forum Controller & Computer Solutions
    Last Post: 02-19-2008, 11:12 AM
  2. support address for IH
    By carlquib in forum Charter Oak Automation Support Forum
    Last Post: 02-27-2007, 06:33 PM
  3. Email Address Pitfalls
    By widgitmaster in forum Computers / Desktops / Networking
    Last Post: 12-14-2006, 02:14 PM
