587,321 active members*
3,232 visitors online*
    Dec 2014
    U and V axis commands in Gcode.
    I am trying to get set up for 8 axis, using the command;
    DefineCoordSystem8(0,1,2,3,4,5,6,7);
    All axis respond in the step response screen and axis x,y,z,a,b,c respond to gcode, but when I try and move channels 6 and 7 with a command such as:
    G1 U20 V20
    I get "G code error Bad character used" and the commands do not go green as they would for other axis. There is also no spot in setup to define axis parameters.
    How do I set up channels 6 and 7 for gcode?
    Cheers
    Alan
    May 2006
    4047
    Re: U and V axis commands in Gcode.
    Hi Alan,
    Although KFLOP supports 8 axes and 8 axes of interpolated motion, KMotionCNC, Mach3, and our Motion Libraries only support 6 Axes of coordinated motion.
    Do you need 8 axes of simultaneous coordinated motion? It is possible to dynamically re-map any of the 8 KFLOP axes to the 6 GCode Axis. Also the remaining two KFLOP axes can be Slaved to other axes. It is also possible to command the remaining axes to move independently with M Codes and such.
    Regards
    TK
    http://dynomotion.com
    Dec 2014
    Hi Tom,
    The application is for welding pipe onto another pipe. There are 2 torches with shared X and Z axis, plus individual Y and 2 rotary per torch.
    Both torches will be performing the same weld(half a circle each), the issue is that initial testing suggested that the best way to weld them is to have the torches slightly staggered in their welds since they start at the same spot (too much heat in one spot otherwise)
    We were hoping for 8 axis of simultaneous coordinated motion, but we can probably get by with a combination of those workarounds thanks.
    Cheers
    Alan
  1. help with 5 axis gcode
    By ethank in forum Rhinocam
    Last Post: 09-25-2020, 08:05 PM
  2. Gcode Turn A axis CCW
    By kNucklBustr in forum Mach Software (ArtSoft software)
    Last Post: 09-24-2012, 06:47 PM
  3. Simple GCode Reference / Commands?
    By WarrenW in forum G-Code Programing
    Last Post: 11-30-2010, 10:03 AM
  4. Gcode commands for Plasmacam
    By jeffery71 in forum PlasmaCam
    Last Post: 11-01-2010, 02:50 PM
  5. Way to take gcode for one axis and mirror it for another axis?
    By genestapp in forum Uncategorised CAM Discussion
    Last Post: 10-09-2010, 04:14 PM
