588,129 active members*
4,835 visitors online*
Page 3 of 3 123
Results 41 to 48 of 48
  1. #41
    Mar 2004
    392
    Re: UB1 Daughterboard - What features?
    Received mine today, thanks Weerasak.
    Now I just need to dig out the soldering iron for the linker.
Name:	2018-03-23 14.03.25.jpg
  2. #42
    Mar 2004
    392
    Attachment 389698
    All soldered now. I'm going to setup my UCCNC test system this weekend, update UCCNC and have a play with the board.
    Do I need and update to UCCNC to enable it to see the UD1 correctly?
  3. #43
    Sep 2005
    1195
    matth,
    So actually we can use ribbon cable assembly or linker between UB1-UD1, but linker need to be soldered. I just knew that.
  4. #44
    Mar 2004
    392
    Yes, you can use either.
    I think it’s worth soldering the linker as it makes a very neat connection.
  5. #45
    Mar 2004
    392
    Wired up a couple of switches yesterday and a SSR so I could have a quick play around with the board and UCCNC.
    Updated UCCNC and Ger's screenset, all works great.
    I must say that the general IO setup is so much simpler and straight forward compared the Mach3.
Name:	2018-03-29 16.23.37.jpg
  6. #46
    The UB1 daughterboard seems to be skewed towards inputs vs. outputs. Is there a reason for that? Any change of a UB2 that is skewed towards outputs??
  7. #47
    Mar 2003
    35538
    Because it's designed for ports 4 & 5 on the UC300ETH, which are mostly inputs.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  8. #48
    Thanks Gerry, knew there had to be a reason.
Page 3 of 3 123
  1. DIY CNC Features - Tell us what you want!
    By DIYLILCNC in forum News Announcements
    Last Post: 07-22-2011, 07:47 PM
  2. What features would you like to see?
    By cncadmin in forum SheetCam
    Last Post: 06-12-2011, 03:06 PM
  3. new features
    By single phase in forum Hypermill
    Last Post: 11-21-2006, 06:31 PM
