603,310 active members*
2,940 visitors online*
Thread: UB1 gnd pin
    Dec 2016
    137
    UB1 gnd pin
    Hello
    I have just a quick question for you.
    I have had the UB1 for a few years now.
    I have never connected the GND pin on the board, but should I do that?
    Connect to mains ground?
    The servo drives is not directly connected to the mains gnd either. There is a GND wire from the servos connected to mains gnd, but it is not connected to the drive. There is also a gnd wire in the encoder cable I think, so everything might be connected through the cables.
    Trying to identify some thiching noises from my Z servo and have allready tried moving both the signal cables and encoder cable without any difference.
    Dec 2016
    137
    Re: UB1 gnd pin
    Screen
  1. Problem when GND XGND and FDW are connected..
    By loundor in forum Spindles / VFD
    Last Post: 04-05-2022, 11:18 PM
  2. Cloudray Laser power supply T100 Shorts digital GND and Earth GND
    By gerardougalde in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 12-22-2020, 03:27 AM
  3. Short earth with 24Vss(gnd) to have signal on endmill can be harmful?
    By sn4k3 in forum CNC Machine Related Electronics
    Last Post: 04-18-2020, 02:33 AM
  4. tierra , gnd y puerto paralelo
    By Diegone in forum Spanish
    Last Post: 12-30-2010, 06:10 PM
  5. G250/251 - signal gnd needing resistor-why?
    By Chris D in forum Gecko Drives
    Last Post: 09-27-2009, 07:05 PM
