I have again ran this UC 100 threw it's paces this Am ,first i ran the lathe from the parallel port and cut a .5x 13x1. pitch thread cut just fine spindle started ran ran G 76 threading cycle.
I wiped out the UC 100 plugin and re -downloaded it to make sure set back up plugin tested functions spindle control as far as M03 S 500 spindle start's.
Tried to run spindle calibration no dice still does not work ,it shoots a line to the top of the scale and refuses to function will not calibrate.
So the i went to the wizard for Mach 3 threading ,i did not want to use my cam program as to eliminate a ghost there ,these are the result's on a none working machine!
Load g76 from the threading wizard with a .5x13x1 thread routine 12 passes 2 spring passes just to get lot's of passes .
Cycle start, spindle does not start , it should ,. X moves to .6 Z moves to 1.1,next move to X.49 Z0 and everything stops and that is it.
What should have taken place is the spindle started it moved to the clearance of the offset of the tool and then to the first cut position to start the G 76
So it does not work ,either there is a bug in the plugin or these function's are not supported it' s that simple !
I will write to John as one of the UC 100's came from him and the other from CNC4 pc two different suppliers ,this was also tested from two different PC,s
I will invite him to do an actual running test of these functions so as to prove me wrong and explain the difficulties that i am experiencing.
