Hi all - looking for some help please. I have a C10s BOB configured so the pins 2-9 pins Common connection is 5V ---BUT there is no 5V there.
C10 is externally powered with 5V and there is 5V on the enable pin....AND on the jumper selection pins (2,3). My C10s is connected to the Port 2 on the UC300
USB to parallel port controller.
Thought I'd post here hoping someone with a UC300 board simulating the LPT port may have already solved the problem. I did see something about pins 18 and 19 need a keep alive signal from the PC but no sure if that affect the COM terminals on the C10
