I am working on converting a AXYZ 4008 router to run on a UC300 + c76 board.
I am trying to hook up the drives but have been unable to get any movement.
The existing setup is a 3 wire connection, one wire to PIN1/PIN2, and individual wires to Pins 6/7. Pin 1 = STEP+, Pin 2 = DIR+, Pin 6 = STEP-, PIN7 = DIR-
Attachment 507482
On the c76, I am using the c78 board which is a rj45 output, here are the pinouts:
Attachment 507480
From the c78, the pins to the driver are:
c78 6410 driver
Pin 2 -> Pin 1
Pin6 -> Pin 2
Pin 4 -> Pin 6 and Pin 7
When powered up, the drive has holding torque. When I use UCCNC to activate the axis, I get 4.7 volts going to the drive signal but again no motion.
Does anyone have experience hooking up to Pacific Industries Drivers? Thanks in advance.
