587,238 active members*
3,853 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller Cards > UC300ETH-UB1 / Gecko G540 / UCCNC Ports and Pins?
Results 1 to 10 of 10
    Jan 2010
    44
    After the recent problems with Mach3 and Windows updates, I am moving away from Mach3.
    One of my new machines will be a Gecko G540 / UC300ETH-UB1 / UCCNC setup.
    After some initial problems getting the software to recognize the hardware, I am now in the process of configuring the Ports and Pins in UCCNC.
    I have the Gecko plugged into the port marked LPT4 on the UB-1 board. How do I know which Port# and Pin# to specify for the motor parameters?
    Thanks for a link or any help.
    Gary
    Mar 2003
    35538
    Re: UC300ETH-UB1 / Gecko G540 / UCCNC Ports and Pins?
    It won't work on port 4.
    It must be used on ports 2 or 3.
    So, the port number is either 2 or 3, whichever one you use.
    And the pin numbers are listed in the G540 manual.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jan 2010
    44
    Gerry,
    Thanks for the quick reply. I've attached a picture of my UB-1. Are you saying that the port marked LPT4 maps to Port2 and LPT5 maps to Port3?
    If so, where is that documented so I can read up and not have to ask here.
    Thanks again,
    Gary
    Mar 2003
    35538
    Sorry, I missed the part about having a UB-1.
    Unfortunately, the G540 will not work with the UB-1.
    Ports 4 and 5 on the UB-1 use pins 2-9 as inputs, and the G540 needs them to be outputs.
    Gerry
    Mar 2003
    35538
    The UC300ETH has 5 ports, but only ports 2 & 3 are "standard" ports, and when the UC300ETH is plugged into the UB1, those ports are already being used by the UB1.
    If you need to use a G540, you'd need to use the 5LPT motherboard
    Gerry
    Jun 2015
    943
    I see no issues with him using the UB1 but using the 5LPT is definitely simpler.
    Mar 2003
    35538
    Please explain how.
    The G540 has a parallel port input, and the only two available with the UB1 are ports 4 and 5.
    On a G540, pins 2-9 are the step direction lines, but on port 4 or 5 of the UB1, these are input pins.
    Gerry
    Jun 2015
    943
    Wiring screw terminal pins of the UB1 to input pins of the G540. Not a simple solution, but could be done. Using a 5LPT is much easier though.
    Sep 2005
    1195
    If we use ESS on this G540, it just replace ESS with UC300ETH-5LPT, easy. I have done this on my machine.
    How to add 1 more axis on this one if we use 5LPT ? It is OK to use BOB such as STV2 (cheap chinese BOB) than connect to port #3 on UC300ETH-5LPT, then the driver (DM542A) is connected to the BOB ? Sorry I ask this question and I do not plan to hijack this thread.
    Mar 2003
    35538
    Yes
    Gerry
  1. UCCNC and UC300ETH-5LPT configuration issue
    By dalai in forum UCCNC Control Software
    Last Post: 03-20-2018, 10:37 AM
  2. Replies: 1
    Last Post: 03-19-2018, 05:01 PM
  3. Not getting any input from PC to CNC Router - UCCNC UC300ETH UB1
    By crash416 in forum DIY CNC Router Table Machines
    Last Post: 11-03-2017, 12:49 AM
  4. Converting to UCCNC & UC300ETH-LPT5 (From Mach3/PP/SS)
    By Mogal in forum UCCNC Control Software
    Last Post: 04-08-2017, 08:06 PM
  5. UCCNC profile needed for Gecko G540
    By curiosity22 in forum UCCNC Control Software
    Last Post: 08-20-2015, 10:32 AM
