603,417 active members*
2,914 visitors online*
IndustryArena Forum: UCCNC Control Software
Page 3 of 22 1234513
Threads 41 to 60 of 429
Discuss UCCNC Control Software here!
  1. Sticky Thread Sticky: UCCNC Macro sharing
    Started by BanduraMaker, 02-02-2015 10:15 PM
    4 Pages
    1 2 3 4
    03-17-2025, 01:44 PM Go to last post
  2. Sticky Thread Sticky: Huanyang VFD Macro/ Plugin
    Started by Dan911, 11-02-2016 04:35 PM
    29 Pages
    1 2 3 4 5 ... 29
    08-21-2020, 10:58 PM Go to last post
  3. Sticky Thread Sticky: !!! Counterfreit UC100 motion controllers are sold on e-bay !!!
    Started by dubble, 10-18-2016 05:58 AM
    controllers, counterfreit, e-bay, motion, uc100
    10-18-2016, 10:11 AM Go to last post
  1. UB1 and stepperonline closed loop driver wiring
    Started by torcher, 12-23-2020 12:07 AM
    11-23-2022, 07:29 AM Go to last post
  2. Uccnc hdbb2 wiring help needed
    Started by the great waldo, 12-17-2017 12:50 AM
    cnc, diagram, hdbb2, uccnc, wiring
    11-07-2022, 11:40 PM Go to last post
  3. UB1 Wiring Questions
    Started by Quixeh, 11-08-2019 11:05 PM
    24v, cnc, grounding, plate, ub1
    10-11-2022, 01:12 AM Go to last post
  4. Question Leaving Mach3 for UCCNC - Hardware migration question
    Started by uspl, 10-09-2022 02:50 AM
    10-10-2022, 06:25 PM Go to last post
  5. zero machine co-ordinates?
    Started by peteeng, 10-06-2022 09:36 PM
    co-ords, machine, mine, peter, zeroing
    10-07-2022, 10:58 PM Go to last post
  6. Servo tuning setting location
    Started by bhdavis1cnc, 09-22-2022 01:26 PM
    backup, cnc, laptop, network, tuning
    09-27-2022, 01:39 AM Go to last post
  7. UC300ETH, M45, C25 - problem with inputs
    Started by motogeeking, 06-27-2017 01:26 AM
    07-03-2022, 10:14 PM Go to last post
  8. Parking spindle after job
    Started by mchesney1, 05-27-2022 01:19 PM
    cam, job, software, spindle, uccnc
    05-28-2022, 02:26 PM Go to last post
  9. Post NEED HELP! UCCNC Software on Surface Grinder
    Started by BGies480, 05-18-2022 08:29 PM
    cnc, grinder, m3x, software, uccnc
    05-19-2022, 04:07 PM Go to last post
  10. UB1 from CNCDrive power up issue
    Started by Delron, 05-13-2022 09:58 PM
    cnc, power, software, ub1, uccnc
    05-13-2022, 10:35 PM Go to last post
  11. Can't install uccnc
    Started by redbone1, 04-02-2021 03:20 PM
    desktop, install, running, screenset, uccnc
    04-16-2022, 10:12 AM Go to last post
  12. UCCNC Dwell Time Sometimes Inaccurate
    Started by botlrokit93, 03-09-2022 03:48 PM
    dwell, issue, machine, software, time
    03-10-2022, 02:39 PM Go to last post
  13. UCCNC and Modbus TCP/IP
    Started by Sigramsik, 01-16-2022 10:15 PM
    01-22-2022, 01:08 AM Go to last post
  14. Tool sensor
    Started by MAHNKEN, 10-24-2021 07:42 PM
    bit, cnc, router, sensor, tool
    10-25-2021, 02:27 PM Go to last post
  15. Z-axis position not holding after reboot.
    Started by bhdavis1cnc, 10-21-2021 09:24 PM
    day, material, position, shut, z-axis
    10-22-2021, 03:19 PM Go to last post
  16. New UC300ETH breakout board.
    Started by ger21, 07-04-2017 03:53 PM
    10 Pages
    1 2 3 4 5 ... 10
    09-22-2021, 09:36 PM Go to last post
  17. touch probe not working
    Started by turosan, 09-08-2021 04:00 PM
    changed, inadvertedly, probe, touch, working
    09-10-2021, 03:07 PM Go to last post
    09-04-2021, 06:28 AM Go to last post
  18. drive issues
    Started by C-Hamm, 08-14-2021 05:58 PM
    08-27-2021, 12:14 AM Go to last post
  19. Spindle RPM not correct
    Started by Borneoben, 08-14-2021 01:10 AM
    calls, correct, rpm, sset, vfd
    08-14-2021, 06:21 PM Go to last post
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
