Hello. I need help understanding how the “jog controller” in the Universal G-coder Sender works.
First of all, this is my first time here and if I'm posting this in the wrong place, please let me know and I'll go to a different forum. Here is what I have: 1.8 degree Nema 23 stepper motor with Rated Current/phase of 2.8A, DM542T driver, Arduino uno, GRBL 1.1, UGS 2.1.9 So, I’m focusing on my Z axis. Don’t have it connected to the machine yet-just trying to test if I have it wired correctly. I will be using a 1204 ball screw on my Z axis-so, that’s supposed to travel 4 mm / revolution. I have the driver set for single stepping (dip switches 5,6,7,8 are all on).
200 steps / revolution. Should translate to 50 steps / mm. I have the $102 variable set to 50. I have the UGS jog controller Z step size set to 4 mm. I expect when I press the Z jog button the Z stepper motor should turn 1 revolution. But it does not. It only turns a little more than 3/4 of a revolution. What am I doing wrong?
