587,227 active members*
3,376 visitors online*
Results 1 to 5 of 5
    May 2012
    32
    Question Unbranded DRO scales like iGage
    I have read on some eBay ad's on these unbranded iGage DRO scales (Shahe made?) that you can cut the scale to custom lengths.
    Is this true? If so what is the best way to cut them? (fine tooth hacksaw, slitting saw on mill, etc.) Any length or some magic multiple like 1/8" 1/4" 1/2"?
    Thanks in advance.
    Bruce
    Feb 2007
    4553
    Re: Unbranded DRO scales like iGage
    Bruce,
    The short answer is 100 percent YES, a high speed cutoff wheel does the job quicker than spreading butter.
    Many users on hobby-machinist.com have done so successfully.
    See attached link.
    https://www.hobby-machinist.com/thre...-be-cut.18344/
    Have a most awesome day!
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Feb 2007
    4553
    Bruce,
    This is a interesting read, you may enjoy it.
    AccuRemote vs. iGaging DigiMag Digital Scale Comparison | Yuriy's Toys
    Jeff...
    May 2012
    32
    TNX Jeff for the info. Looks like I can use a Dremel cutoff wheel or take 2 pieces of wood and clamp (lightly) the scale in between and use a hacksaw to cut the scale.
    The wood being clamped would help keep the plastic cover from ripping up during cutting with hacksaw.
    May 2012
    32
    Yes I have been to Yuriy's site already and plan on making this for my lathe so only need X and Z.
  1. G540 and unbranded steppers
    By RaptorZ in forum Gecko Drives
    Last Post: 03-16-2018, 05:34 PM
  2. Unbranded Linear profile Rails/blocks from China
    By Dan911 in forum Linear and Rotary Motion
    Last Post: 06-08-2016, 12:55 AM
  3. Chinese 60w unbranded 700x500mm opinions
    By Fleshinachair in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-24-2016, 09:53 PM
  4. Import Scales vs really cheap import scales
    By joeturner in forum Benchtop Machines
    Last Post: 08-18-2010, 07:56 PM
  5. DRO - Glass scales or cheap Chinese digital scales?
    By strandbygaard in forum Benchtop Machines
    Last Post: 04-05-2010, 03:01 AM
