587,083 active members*
2,952 visitors online*
Results 1 to 8 of 8
    Jan 2009
    23
    Unhook a Servo 300
    I am trying to unhook the barfeeder. I thought I needed to switch parameter 315 bit 7, from a 1 to a 0, but all attemps have not worked. Is this the correct parameter? The lathe is a 2008 SL20, I tried switching the "write enable" pararmeter in the Setting/Graphic, #7 and then E-stop, but it will not allow me to change 315.
    Thank you in advance,
    Feb 2010
    1184
    Quote Originally Posted by vwilmot View Post
    Be sure to press the ENTER button when changing settings otherwise it will not take.
    Parameter 315 is to tell the machine if it is a brush or brushless bar feeder.
    I believe you are looking for Par 390 Bit 3.
    You can get the manual for the Servo 300 here: http://www.haascnc.com/doclib/manual/96-0013.pdf
    It will explain setup and operation procedures and also lists what parameters are used for the barfeeder.
    Hope this helps.
    Jan 2009
    23
    Thank you for your quick response. I did download the updated pdf, and all the parameter info was the same as my hard copy. I tried changing parameter 390, but the system refuses to change, it acts like its still write protected. Parameter 390 bit 3 "Disabled" is currently set to 0.
    Thanks again Haastec.
    Feb 2010
    1184
    Quote Originally Posted by haastec View Post
    You did not indicate if you were doing this.
    When you change a setting, if the highlighted value/message is flashing, then the control did not accept the change.
    Setting 7 turned to OFF and the machine in E-Stop is all that is required to change parameters (excluding purchased option parameters)
    Jan 2009
    23
    Sorry, yes I use the Write/Enter button.
    Aug 2010
    579
    Haas Factory Support
    Has your issue been resolved?
    Thanks,
    Ken Foulks
    Jan 2009
    23
    No, I did my local HFO and they had a field tech call. He suggested Parameter 611, but it was already a "0". The barfeeder motor/encoder is disconnected without issue. But when I disconnect the amphenol connections at the barfeeder, opon boot up I get 2 alarms, #762 V Cable Fault and #134 Low Hydraulic Pressure. I am open to ideas, and I thank you for your time.
    Aug 2010
    579
    Please send me an email with your contact info and serial number. [email protected]
    Thanks,
    Ken Foulks
  1. aniulam 3300mk servo amps. for a servo transformer
    By Dave Rothermel in forum HURCO
    Last Post: 05-10-2012, 04:23 AM
  2. Sell Servo Motor, Servo Drive by GSKcnc.com from China
    By salecnc@hotmail in forum News Announcements
    Last Post: 06-03-2008, 08:55 PM
