Can Anyone Explain The Whole Process Of Uninstalling From One Computer To Another. I Don't Want To Purchase A New Liscense ... Just Take Off My Old One & Put On My New One.
If you are using Version 22 there is no problem and you do not have to uninstall. But if you are using version that do not have a dongle (code required) then you must contact Bobcad to install on a new PC. The code is based on when it is installed and this means it will always require a code from them.
Do not uninstall and reinstall unless they are open to give you the code!
