Hi All,
I got my Rockcliff router working again after a long period of a crashed computer and broken z-axis.
I am having problems with getting the correct units in SolidCAM. In solidworks, I have it defauted to inches. When I created my part, it was all in inches.
Under tool settings in SolidCAM, I have it set to inches (see file). The part I created was only 4" long so I know if fit on my router table. It seems that once the code gets translated and I hit run on my machine the units are all wrong. For example, the DRO would be in the thousands or I tried it again this time leaving the part in mm and it converted it to mm which was real wrong. (.051in became .0021in) How can I get the g-code to create inch code?
Also, it seems that once the part has been created in SolidCAM, it does not let you change the units?
skipper
