Well, we received our 4020HT Reman and it is sweet!!
Other than the little decal on the front of the cabinet stating "Fadal Factory Rebuild" it is a new machine. It came wrapped in plastic (cool, with the Fadal logo all over it!!), tarped, and bolted to an obscenely stout skid.
It shipped and was delivered when they said it would, no complaints at all.
I would say you could probably find a cheaper Fadal out there, but the confidence you get when you key up the control and see 0.00 hours on the machine is worth the extra$$.
The only problem we had was the plastic stretch wrap bent and eventually broke our Block Skip switch and the little knob on the MPG. Both items were replaced immediately. I say not bad for a machine traveling on a flatbed truck from CA to TX!!
In short, I highly recommend one if you have the means.
Thank you all for your input!!
Respectfully,
James Winn
Sierra Machining & MFG., LLC
