603,839 active members*
3,805 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Upgrade Nema 17's to 23? Which stepper driver to use?
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Mar 2015
    11
    Re: Upgrade Nema 17's to 23? Which stepper driver to use?
    I picked up the KL23H276-30-8A steppers. They may not as much torque, but from some of the back and forth here, they seem to be a solid option.
    I'll check into the HTD series belts. I saw the XL belts are good up to 1/4 hp, and that's pretty much where my machine would be. Having something that can handle more would certainly be more ideal.
    I went with acme rods mostly because of cost, but also because I couldn't find ball screws for a reasonable price that would match my linear movements. Hopefully they'll at least get my started, and I can upgrade them later in the future if I need to. The project has also scaled up a bit from my initial expectations of when I started this project and began buying parts. Sometimes I just need to step back and remember that this is my 1st CNC build and is still a learning process. I built a 3D printer about 4 years ago, so I thought I'd be ready for a build like this, but didn't realize all the nuances and how everything works together. I've really learned a lot.
    But now that I have the 282 oz/in motors with the 10tpi acme screws, what would the most ideal gear ratio (if gearing is used) to drive it? I don't want to do direct drive inline because it'll make the motors stick out the back and sides too far. Also, how much current will I need the 48v psu to be to drive these 4 motors?
    Attached are images of what I'm planning the machine to look like. I still need to upgrade the 3D model from the nema 17's to 23's, but most else is there.
    Attachment 275396 Click image for larger version.
Name:	cnc prelim3.jpg
  2. #22
    Mar 2003
    35494
    I'd try a 2:1 reduction on all axis.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  3. #23
    Mar 2015
    11
    Even on the Z?
  4. #24
    Mar 2003
    35494
    Yes. Small pulleys are cheap, you can try some different ratios and see what works best.
    If you don't have the screws yet, you'd be better off going with a .2 or .25 lead, which will be much more efficient than the single start screws. You'd gear these 1:1, and get the same effect as the 1:2 gearing with the single start screws, but have more power due to better efficiency.
    3/8 X .200 Right Hand Hi-Lead Lead Screws & Nuts for Power Transmission - Roton Products, Inc.
    3/8 X .250 Right Hand Hi-Lead Lead Screws & Nuts for Power Transmission - Roton Products, Inc.
    3/8 X .375 Right Hand Hi-Lead Lead Screws & Nuts for Power Transmission - Roton Products, Inc.
    Gerry
  5. #25
    Jan 2005
    1695
    I am using the 282s on all 3 axes of my sx3 mill. Direct drive on x and y, 2-1 reduction on the 115lb z axis.
Page 2 of 2 12
  1. Nema 17 Stepper motor on Nema 23 driver
    By Thomas T in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-21-2014, 08:59 AM
  2. Best Nema 17 stepper for Gecko driver?
    By ArtCAMinski in forum Stepper Motors / Drives
    Last Post: 01-05-2013, 06:13 AM
  3. Savebase - 3 Axis NEMA 23 Stepper Motor Driver CNC Kit + Software
    By nss1024 in forum Want To Buy...Need help!
    Last Post: 03-03-2011, 12:29 AM
  4. cheapest driver for nema 17 bipolar stepper motor
    By cheater76c in forum Stepper Motors / Drives
    Last Post: 03-01-2006, 03:30 AM
